Old 07-05-2008, 10:10 PM   #1
blackicecobra's Avatar
02 Mustang GT Brake Bleeding
Anyone know how to bleed brakes on an 02 GT? Please post an explanation or links to articles if you can. Thanks.
So, you think you're having a bad day? You woke up this morning..........didn't you?
blackicecobra is offline   Reply With Quote
Old 07-06-2008, 11:21 AM   #2
member B.E.D. Racing
sonicblue03's Avatar
Raised the car off the gound and remove all wheels or you can do the rear first than the front.
Fill the master cyl.
Have another person slowly depress the brake pedal 3 to 4 times and hold it.
Slowly open the bleeder on the Right rear cal. You can attach a clear piece of hose to the bleeder and use a container to catch the fluid. Just repeat the depress and hold till fluid is clean and air free. Then move to the Left rear,Right front and lastly Left front. Always check the master to make sure it is at least half full.
If you bleed your system alot(as I do) check this out it eliminates the need for a second person or pumping the pedal.
TrackHaus sells brake bleeding tools and the Motive brake bleeder
97 Rio Red Cobra(Gone but not Forgotten)
2003 Sonic Blue Cobra
2005 Corvette Coupe
2008 Pathfinder
sonicblue03 is offline   Reply With Quote
Old 07-08-2008, 08:40 PM   #3
LoneStarStangs Addict
Wiked's Avatar
If you still have a problem you have to bleed the master cylinder under the hood.
Quote of the Month- If all of you had a chance to have a 1967 GT500 clone you would jump on it, and dont say you wouldnt. I have honestly started realizing lately that most of us on this web site are a bunch of hating ass hypocrites. I my self would like to change my ways, why not join me? - Me
Wiked is offline   Reply With Quote
Old 07-10-2008, 10:27 PM   #4
Don't hate!
Trader Rating: (20)
So if you have air in the ABS pump, you'll never get that air out. Vacuum bleeding or pressure bleeding is the best method. To get air from them pump out, you either need an ABS bleeder (hand held tool that is equipped with a brake bleed function)............ or
Conventionally bleed the system as normal, then take it for a quick drive and lock the brakes up a few time to get the ABS to activate (this self bleeds the air) then bring it back and bleed conventionally again.
Be sure the level in the master never drops below the minimum mark or you will trap more air and have to do it all over again.
Old 07-11-2008, 02:44 PM   #5
METAL!
BlackSunshine01's Avatar
we had to bleed my master when i did my brakes.
