Old 03-13-2008, 03:51 PM   #1
04 PI crate motor swap in 97 GT
I recently bought a 97 GT/auto with a bad motor..(not sure what is wrong with it)...it has been sitting for 3 yrs...so I ordered a 04 PI crate stock crate motor...is there anyone or a website that will tell me what will have to be changed out to make the swap easier..like I know the thermo housing needs to be swapped out, cuz the new one will put the hose right in sight of where my old coil pack need to go..and a few other small things..Im new to the mustang scene and would like to get the upper hand when I do the swap..thanks for any help...
97-Blk_GT is offline   Reply With Quote
Old 03-13-2008, 03:59 PM   #2
You will never get this
Magnapack97's Avatar
shoulda bought a used termie motor. This might help. NPI to PI engine swap how to guide - Mustang Forums at StangNet
Old 03-13-2008, 04:04 PM   #3
whats a termie motor
Old 03-13-2008, 04:49 PM   #4
Do The Stanky Leg!
semperfimrn1's Avatar
Send a message via AIM to semperfimrn1
motor that comes on the 03-04 COBRAS... supercharged
semperfimrn1 is online now   Reply With Quote
Old 03-13-2008, 04:52 PM   #5
32 vavle 4.6 engine which is stock on cobras, as apposed to the 16 valve GT entine. I dont know man, its hard to say which would have been a better decision. Its really up to you, personally I would have done the same as you did, UNLESS a 32 valve engine was available for the same price, AND I KNEW the precise condition of that engine. Especially termie motors and the abuse it might have been put through. So for peace of mind, security, $$$COST and daily driving, I would have gone with crate Gt 4.6 as well. If your concerned with HP Potential, than the termie engine, would have been way better.
blueink is online now   Reply With Quote
Old 03-13-2008, 04:58 PM   #6
no..I really jus wanted reliability...weekend car..and an easy swap..bought the motor for $3400 shipped..everything is new..it is an end of the production run motor..Im having the auto tranny rebuilt..since it was sittin for 3 yrs..and ordering parts for it..long tubes and the usual bolt ons..not tryin to be the fastest..jus quick and working on the looks..like I said..it sat in some apts. parking for 3 yrs...so it needs some TLC..
Old 03-13-2008, 05:07 PM   #7
4 valve
seco's Avatar
share the same point of view regarding reliability ... hope everything works out with your swap
Old 03-13-2008, 05:16 PM   #8
yup wise choice! I would have done the same! were u get it from? try to get a 5sp in it man!
Old 03-13-2008, 05:53 PM   #9
I got it off of ebay and out of arlington...Im not a 5 spd person..prolly driven a stick like 4 times in my life..haha...crazy..huh...Im no good...I like to eat a burger and drive..haha
Old 03-15-2008, 10:23 PM   #10
LOL @ your mom
You'll need to swap a few parts over to make the 04 compatible with the 97.
The timing cover will need to be reused, all the accessories transfer over, the t-stat neck is the same for all years of a 2V. You will basically keep everything from the stock motor and just transfer it over. You'll have to transfer the fuel rails, coil packs, plug wires, egr tube, and most everything else is ok.
I did a 2000 engine in mine which replaced a 96 motor
Old 03-15-2008, 11:54 PM   #11
Im gonna have to switch stat housings...the 04 one puts the hose coming right over where I need to fab up a bracket to keep my coil packs..the motor has all new accessories..alternator & pwr steering already..so wont have to switch the timing housing..I am gonna put a 97 stat housing to reposition the hose outlet..mine on the motor in the car is crusty..haha...thanks for all the input..
Old 03-16-2008, 12:02 AM   #12
LOL @ your mom
I have a housing from a 96 if you need one, good shape still and I can ship it if you need it. The belt routing is different too from a 97 to an 04.
Old 03-16-2008, 09:34 AM   #13
Humble Pie (18-1)
Stang6uy's Avatar
New & Used Engines
should have bought this one for 1800 it's the same thing only lighter cause it's an aluminum block......
1983 GLX Blu-sold
1989 Blk coupe-sold
1990 Blu hatch-crushed
1993 white vert-sold
1985 gt hatch white-sold
1990 Blk coupe-sold
1990 Blk coupe-sold
1990 red hatch-sold
1995 yellow gt-sold
1996 Blk gt-sold
2000 Blk gt- gave to brother
1990 Lincoln LSC-sold
stangless for now...
Old 03-18-2008, 12:46 AM   #14
weird thing happened to me today...I decided to try and start my stang again..the damn thing fired right up...which was pretty good for sittin for 3 yrs...I got it started once before..but ran like busted ass...today..fired right up and purred like a kitten...other than a lil valve chatter around 3-4K...prolly due to 3 yr old gas...weird though..I was told the motor was bad...supposed to have a bad cylinder per a Ford Dealership....no check engine light...sorry for ramblin..jus thought I would tell yas...
Old 03-25-2008, 07:28 PM   #15
1mean4.SIK's Avatar
i think your going to need to keep your old coil packs and splice the wires to adapt to your wiring harness, it should bolt on only problems are basically the wiring harness.
1mean4.SIK is online now   Reply With Quote
