Old 02-27-2008, 11:04 AM   #1
Black Betty
Moostang09's Avatar
Send a message via AIM to Moostang09
05+ cut out for rear bumper
I am looking for the diagram or w/e it is called so i can cut my rear bumper for dual exhaust. help asap would be awesome.
GT Takeoff Exhuast - 02/17/08
H-Pipe/Duals - 03/14/08
Moostang09 is offline   Reply With Quote
Old 02-27-2008, 11:31 AM   #2
Regret nothing. Fear less.
Stumpy's Avatar
when my exhaust was installed on my 03 v6, the bumper stayed the same. they just put on longer hangers so it would hang just below the bumper.
I have come here to chew bubble gum and kick ass and I am all out of bubble gum.
Men are natural destructors. We pop right out of the man-womb and start on a life-long tirade of progress by tearing down the Earth with our mighty, man-manly man-fists.
Stumpy is offline   Reply With Quote
Old 02-27-2008, 11:34 AM   #3
Black Betty
Moostang09's Avatar
well i have an '08 and on the right side (passenger) there is a cut. i want to recreate that cut out on the left side (drivers side)
Old 02-27-2008, 11:39 AM   #4
Stumpy's Avatar
okay, now i understand. i knew your's is newer but didn't remember that they put the cut in the bumper already.
Old 02-27-2008, 11:46 AM   #5
Cool Kid
cmschlatt's Avatar
http://pysales.com/inst/SFM68-bumper-cutout02.pdf
cmschlatt is offline   Reply With Quote
Old 02-27-2008, 11:49 AM   #6
Black Betty
Moostang09's Avatar
thx i just found that from google. appreciate the help!
Old 02-28-2008, 12:12 AM   #7
tx_zstang's Avatar
It's really quite easy to do a good cutout. With the template in the link, it will probably be a little easier; I didnt have a template when I did mine.
I took some posterboard, made a template from the passenger side, then essentially flipped it over to mark the driver side. I lined it up and marked it so that the ends and.or markings were lined up to match against one of the bends in the bumper and then flush with the bumper toward the license plate, then used tape to secure it and then marked out the existing hole. Then cutout the pattern in the posterboard, check its cut and alignment ON THE PASSENGGER SIDE to make sure it is accurate, then transfer it over and mark the driver side.
Cutting out the hole is easiest if using a flexible saw, like a coping saw. Take your time, cut carefully: you can't undo your mistake! After cutting it out, take a file and gently cleanup the cut edges.
Not a great pic, but the after-results. I'll have a better pic this weekend.
-- Mike --
2005 V6 Automatic, 300+ RWHP
Vortech Supercharger, air-air intercooler, blow-through setup; 42#s; maf.ia; 40mm BOV; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; 3.73s, T-Loc., LPW girdle, alum driveshaft; Steeda panhard bar & brace, CHE lca's; Mac LT headers, high flow cats
tx_zstang is offline   Reply With Quote
Old 02-28-2008, 07:45 AM   #8
Black Betty
Moostang09's Avatar
that is very helpful. once i get mine done i post sum pics up. i maybe do like a walk through will im doing it.
