Old 10-30-2007, 12:59 PM   #1
Snake 42
Red face 06 GT Throttle Body Problem
Okay, it's my turn to say I screwed up. I disassembled the throttle body on my stang because it seemed (to me anyway) that the throttle blades did not open all the way. After finding no adjustments I reassembled and reinstalled the throttle body and now all the car will do is start and idle. When I try to add throttle nothing happens. I've disassembled the throttle body again and checked the drive moter and it rotates like it should but I can't seem to get it back together where it will drive the throttle plates.
Any ideas or advice anyone?
Snake 42
Snake 42 is offline   Reply With Quote
Old 10-31-2007, 09:08 AM   #2
99 percent the throttle spring wasnt installed correctly almost always what happens
you have to install it then twist the plastic piece that holds it 180 degreees so the tabs engage after you bolt the motor plate back on
PSI
Performance Solutions
210-655-6546
10811 nacogdoches road
San Antonio TX 78217
cmr tuners and full service
performance shop.
Old 10-31-2007, 02:06 PM   #3
Snake 42
Smile
Snake 42
Allright, the preload spring was indeed the problem and now that I have clocked it correctly my Baby is back on the road. I would like to thank you for the advice as now all is well in the Mustang World.
Snake 42
Old 11-01-2007, 06:07 PM   #4
when driving it didnt seem like it opened all the way up? or with your fingers? Because before a tune it will not open upp all the way at times in the low gears.
Dean when you do a tune is it possible to quicken how fast the tb opend up uon mashing the throttle from a roll?
Old 11-01-2007, 06:07 PM   #5
MonsterFishKeeper
STANGER_SC's Avatar
Glad to hear that Snake!!!
STANGER_SC is offline   Reply With Quote
Old 11-02-2007, 08:50 PM   #6
yes we can totaly remap the throttle vs your foot input ..
PSI
210-655-6546
performance shop.
