I'm in the market for some 18x10 in the rear of a 92 coupe, it has a liincoln mark 7 rear which is the length as an sn95 what offset and a good tire size, opinions please
I think you can still get away with the 94-04 offset (24mm i think) but not too sure if they will stick out past the fender. You might have to go with 05-up offset
Yea I think its the 05+ offset I just want to make sure before I order and if anybody knows a good tire size
I have 20 x 10s with an 05 offset on a sn95 rear. Fits nice with the fenders rolled and 285's.
I used to run 18x10s with 285s on my old 91GT, it had a stock length 5 lug rear end in it so I was using 94-04 offset wheels. With the 285s I still had more then enough room to comfortably fit a 295 tire...I squeezed a nitto 315 on there with a 1/4" spacer (might have been a little thicker then 1/4"), I had to remove the quad shock and massage the inner fenders with a BFH. It was a snug fit but looked badass nonetheless
cool thanx for some of that info ill guess ill be going wit the 05+ offset wit some 285s
Ok so finally gona order them wheels gona go wit the gt4s, what's size tire I know some 285s but what did y'all run on urs full size please muchos thank u's
the mark vii rear is 1.5" wider than a fox rearend
1989 mark vii lsc with a 5.0,aod,8.8 w/ 3.27's open diff 2 1/4" catback with glass packs dumped
yea sir..... which is the same as the sn95 rear, i just wanted a tire that fits in the wheel well perfect and not rubb. i know that i will have to roll the fender but thats is no bigge
Most likely will need to beat the inner fender well also. I have 17x8 all arond on my 85 with a 98 cobra complete rear axle. I have no rub in the rear but a 10 needs a little massaging from what i understand.
85GT FACH1 FINISHED
i know this is kinda old but not that old, would i be able to get in to the 3s as far as the rear goes found some front tires just want it to look badass in the back, i know i will have to beat the inner fender with the bfh method and roll the fenders, any help would b appreciated
What do you mean get into the 3s?
I don't think you'll be able to fit 305s under the rear with sn95 length axles. Unless you have 36+mm offset rims.
I think it should be fine... I have the Sn95 length axles, and I'm running a 17x9 +45mm offset in the rear (05+ wheel size).. you will want a 45mm offset to fit correctly.
