Results 1 to 12 of 12
Thread: 2 row 1" tube radiator vs. 3 row radiator
    May 2008
    well i finished the exhaust and drove the stang and it gets hot. I should have figured so cause even the old motor (stock 289) got hot. I am looking to get a new radiator and have been looking at the ones on ebay. I have two choices. One is a two row aluminum with 1" tubes. the other is a 3 row aluminum with i guess standard sized tubes. Which one do you think would cool better. Btw I am also going to get a fan shroud and go with a clutch fan instead of my elec. fan. Or should i go with a Aluminum 4 row??
    Jun 2003
    Trashcanistan
    I just ran a 3 row brass and mine cooled just fine. That without a shroud too.
    Dec 2003
    SanAntonio
    I picked up a heavy duty all brass 3row from Lone Star Radiator for my FOX and with a 180 stat no shroud and an elec fan i can not get the thing over 190-2200 deg. I would not go back to a clutch fan it robs power and isnt near as efficent as an electric.
    What motor is in it now?
    Are you sure the head gaskets are not installed backwards? It is real easy to do and it will block the rear passages and the car will run hot.
    Also do you have the correct W/P for your app. A reverse rotation pump wont work on a v belt drive and vice versa. Tough part is there is no way to tell by appearances they look the same.
    85GT FACH1 FINISHED
    May 2008
    its a carbed 5.0 motor and has hci. Im 99 percent positive the headgaskets are fine. when i put them on i double checked. I do have the v belt but its a hi volume waterpump made for the vbelt as well. I just wanted to make sure come august i dont overheat. I talked to the one guy on ebay with the 3 row radiator and he said i should have no problem with the 3row. He has 100 percent positive feedback so i think i might go with his.
    Dec 2003
    SanAntonio
    How much is it? the one I got local was 180 w/taxes. It is a solid peice I have used this shop many times always quality work/products. I looked at alum as well when I pcked it up and I saved about 2 bills easy.
    85GT FACH1 FINISHED
  6. #6
    Lock and Load Bitches Regular Member Matt56's Avatar
    Aug 2008
    San Marcos Tx.
    mishimoto has great radiators, they have a no questions asked warranty, you show then proof of your mishimoto leaking and they send you a warranty form. once you mail or fax it in they have one shipped out within 24-48hrs
  7. #7
    Dec 2003
    SanAntonio
    I had put a new one in my L form Lone Star Rad and had a leak I drove over with the bad one they checked it and I drove home with a new one in about 15 min.......
    I like dealing with local peeps when I can
    85GT FACH1 FINISHED
  8. #8
    Dec 2007
    Marion
    Becarefull of getting too thick of a radiator, I have worked on Larry's old '66 a couple of times for the current owner, there is not much room between the radiator and the engine because of the thick radiator. So what electric fan do you have? If you don't have a fan that moves at least 2800 cfm you will need one, actualy getting a fan that moves over 3000 cfm helps. I prefer electric fans, I hate timing engines with engine driven fans, always afraid a blade will come off and they eat up a lot of power. The two row aluminum radiator should be fine.
  9. #9
    May 2008
    yesterday i ordered a brass/copper 3 row 20" radiator for a 67 mustang. Its 3 inches wider than the 65-66. So hopefully that will help this summer. And i ordered a fan shroud. Another thing i was doing wrong was running without a thermostat.
  10. #10
    Dec 2007
    Marion
    Quote Originally Posted by 65mustangscott View Post
    Not having a thermostat is not good, the water flows to fast through the radiator and so very little heat is removed from the coolant. I run a restrictor in my car, just so I don't have to worry about the thermostat sticking and I have a restriction to slow the water in the cooling system.
  11. #11
    Dec 2003
    SanAntonio
    #in wider means 1 1/2 inches on each side will be covered up by the radiator support and get no air flow unless you open up the hole.
    I would suggest a 180 t stat.
    85GT FACH1 FINISHED
  12. #12
    May 2008
    im going to cut it open. And yeah im either going with the 180 or the 190.
