Old 01-06-2008, 12:59 PM   #1
God's gift to Dell
SCobraVT99's Avatar
2003 Mustang GT oil Change
On my oil cap it says 5W 20
Can I use 10W 30? What oil should I be using? Or do I need to use 5W 20?
SCobraVT99 is offline   Reply With Quote
Old 01-06-2008, 01:03 PM   #2
tire's Avatar
yes. (and i don't care what others might say)
almost all late model cars use really thin stuff like 5w nowadays. 10 will work fine though!
wait... it says use 5w20? i have been out of the loop for a couple years but i thought it was 5w30?
austin
Old 01-06-2008, 01:10 PM   #3
God's gift to Dell
SCobraVT99's Avatar
it for sure says 5W 20
Old 01-06-2008, 01:16 PM   #4
use 520.... the tollerances on newer cars are MUCH tighter than older cars... i've seen oil pumps burn up and cause catastrophic failure due to using oil that is too thick
Old 01-06-2008, 02:42 PM   #5
thunderchicken's Avatar
Also,if you were to use any other weight of oil other than specified by your owners manual,oil cap,or dealer recommendations,it will effect you gas mileage....dramatically aswell......
Old 01-06-2008, 03:16 PM   #6
Aviator Stang's Avatar
What I did was use 5w 30.
Aviator Stang is offline   Reply With Quote
Old 01-06-2008, 03:29 PM   #7
why? were you burning oil? i dont understand ppl that think they're smarter than the engeneers who designed their car... unless you really have a reason, stick with what they tell you... "side molding removed" is not a mod that requires thicker oil..
Old 01-06-2008, 04:45 PM   #8
KEN LEEEEEE tu libu dibu daucoo......
TheBocSez's Avatar
It was always explained to me that Ford and other manufacturers went with thinner weight oils in order to gain additional fuel milage needed to meet standards and that it actually has nothing to do with clearances. Im sure he will be fine with a 10wt oil.
Old 01-06-2008, 05:10 PM   #9
im gonna have to agree with the dave... use what the factory calls for. why even tempt something bad, just use what the motor calls for.
Clicky
Old 01-06-2008, 11:45 PM   #10
AdRock's Avatar
TheBocSez is right. The tolerances in the new 4.6's compared to the older ones haven't changed. The weight of oil changed so that Ford could get better mileage for the Feds, thazt's it. I run 5w-30 and wouldn't put anything thinner in there. The engine isn't gonna have a problem with the 5w-20 at all if that's what you rather run.
'02 Stang GT
And let me tell you something
Cause you can't bring me down
Old 01-07-2008, 11:32 AM   #11
God's gift to Dell
SCobraVT99's Avatar
I put Castrol 10W-30
Old 01-10-2008, 09:32 AM   #12
Holy crap....
Trader Rating: (14)
That is true, but David is right, the bearing clearances in the 4.6 are extremely tight. The 5W30 is choice, but 5W20 if for better gas mileage.
Here are basic specs on crank clearance 0.00098-0.00197 in
And rod clearance spec 0.0010629-0.0027165 in
So do the math and tell me that a 10W30 oil will pass through with ease.
Yes it will, but it strains going through.
Originally Posted by hoss302
Old 01-12-2008, 12:12 PM   #13
lasersnake96's Avatar
Trader Rating: (3)
x2, i run 5w20 mobil one in my Lightning and GT with good results
Originally Posted by H0SS302 View Post
Have you seen a vert with a tan top? looks really gay
2004 Cobra/Daily 2003 Accord
Past rides: 4 93 cobras, 96 cobra, 99 cobra, 03 cobra, 8 fox bodies, 3 94-95 gt's, 04 Lighting, SVT contour, 02 Saleen, 03 Mach 1, 02 GT, 65 Coupe
lasersnake96 is online now   Reply With Quote
Old 01-12-2008, 05:33 PM   #14
Evil Angel
Bigdrumma22's Avatar
Trader Rating: (3)
Wink
I use Mobil 1 Full synthetic 5W-30 simply because it's not new anymore and wasn't when I got it. If bearing tolerance has anything to do with it, mine have grown with mileage. I've got a little over 71k, so I don't see an issue with using a little bit thicker oil unless the car is brand new, or you're breaking in the engine. It's not like he's trying to throw straight 40HD in or something. I haven't had any problems and usually get 19-20 mpg.
Old 01-12-2008, 11:25 PM   #15
TonyToughNuts's Avatar
holy crap!! 19-20?? see, use 5-20 like it says on yours (and mine) i get 26 if i'm easy and 21 if i'm tearing around. crap. i get 17 doing 135 mph on I-10 between Ft. Hood and Ft. Bliss! and that is stock minus a CAI and a home P&P TB/plenum.
you laugh cause it's funny, i laugh cause it's true
TonyToughNuts is offline   Reply With Quote
Old 01-12-2008, 11:32 PM   #16
Evil Angel
Trader Rating: (3)
Wink
Well I thought someone might come up with numbers like that. To be more specific, I get 19-20mpg mostly street, lots of traffic, lots of lights in my area. Highway only time I measured I got 23mpg. Mine is stock with cold air, catback, and offroad H. I only have 2 02 sensors also which would effect my air/fuel ratio. There are a number of variables that factor in, tire size, etc. How many miles do you have and what trans? Due to the overwhelming thoughts on this, next oil change, I think I'm going with the 5W-20 to see if there is any significant difference. I doubt there will be, but we'll just have to wait and see.
Old 01-13-2008, 09:56 AM   #17
i use the non-synthetic 5w30 as that is what my blower likes.
MIKE
'86 GT:high 12's
Sold
'01 GT:low 11's
for sale
Old 01-13-2008, 10:16 AM   #18
Holy crap....
Trader Rating: (14)
If you have bearing tolerance that grows with mileage, then your engine has issues.
Old 01-13-2008, 10:20 AM   #19
Evil Angel
Trader Rating: (3)
Question
All I mean is engine wear. That is what engines do with accumulated mileage isn't it?? Are you saying no matter how old or how many miles an engine has, you should always you the specified oil?
Old 01-13-2008, 10:21 AM   #20
Holy crap....
Trader Rating: (14)
You must not know a modular then do you?
