2004 stock springs and 95mm C&L mass air
i am trying to clean out the garage, these are parts i took off of my 2004 Cobra.
stock springs- $50 95mm C&L mass air meter with cai and filter- $100 obo stock throttle body- $40 stock flywheel- $40 here is a pic of the C&L http://img.photobucket.com/albums/v4...o/P1010416.jpg
2004 Whippled Silver Cobra rebuilt lower end built str8t axle Sponsored by Lethal Performance in SA |
#4 | |
Is the flywheel for a 5 speed? 8 bolt pattern & 11" clutch?
Nope, was lookin for an upgade for a T-45 and switching to an 11" clutch.
