View Single Post
Old 01-23-2006, 08:20 PM   #1
12second5.0
Check ya later!
OBD-2 Diagnostic codes
P0100- Mass or Volume Air Flow Circuit Malfunction
P0101- Mass or Volume Air Flow Circuit Range/Performance Problem
P0121- In-Range Operating Throttle Position Sensor circuit failure.
P0122- Throttle Position Sensor circuit Low Input.
P0123- Throttle Position Sensor circuit High Input.
P0125- Insufficient Coolant Temperature to enter Closed Loop.
P0126- Insufficient Coolant Temperature for Stable Operation.
P0102- Mass or Volume Air Flow Circuit Low Input
P0103- Mass or Volume Air Flow Circuit High Input
P0104- Mass or Volume Air Flow Circuit Intermittent
P0105- Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106- Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107- Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108- Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109- Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110- Intake Air Temperature Circuit Malfunction
P0111- Intake Air Temperature Circuit Range/Performance Problem
P0112- Intake Air Temperature Circuit Low Input
P0113- Intake Air Temperature Circuit High Input
P0114- Intake Air Temperature Circuit Intermittent
P0115- Engine Coolant Temperature Circuit Malfunction
P0116- Engine Coolant Temperature Circuit Range/Performance Problem
P0117- Engine Coolant Temperature Circuit Low Input
P0118- Engine Coolant Temperature Circuit High Input
P0119- Engine Coolant Temperature Circuit Intermittent
P0120- Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121- Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122- Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123- Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124- Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0125- Insufficient Coolant Temperature for Closed Loop Fuel Control
P0130- O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131- O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132- O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133- O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134- O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136- O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137- O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138- O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139- O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140- O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142- O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143- O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144- O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145- O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146- O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150- O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151- O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152- O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153- O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154- O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156- O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157- O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158- O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159- O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160- O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162- O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163- O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164- O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165- O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166- O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170- Fuel Trim Malfunction (Bank 1)
P0171- System too Lean (Bank 1)
P0172- System too Rich (Bank 1)
P0173- Fuel Trim Malfunction (Bank 2)
P0174- System too Lean (Bank 2)
P0175- System too Rich (Bank 2)
P0176- Fuel Composition Sensor Circuit Malfunction
P0177- Fuel Composition Sensor Circuit Range/Performance
P0178- Fuel Composition Sensor Circuit Low Input
P0179- Fuel Composition Sensor Circuit High Input
P0180- Fuel Temperature Sensor A Circuit Malfunction
P0181- Fuel Temperature Sensor A Circuit Range/Performance
P0182- Fuel Temperature Sensor A Circuit Low Input
P0183- Fuel Temperature Sensor A Circuit High Input
P0184- Fuel Temperature Sensor A Circuit Intermittent
P0185- Fuel Temperature Sensor B Circuit Malfunction
P0186- Fuel Temperature Sensor B Circuit Range/Performance
P0187- Fuel Temperature Sensor B Circuit Low Input
P0188- Fuel Temperature Sensor B Circuit High Input
P0189- Fuel Temperature Sensor B Circuit Intermittent
P0190- Fuel Rail Pressure Sensor Circuit Malfunction
P0191- Fuel Rail Pressure Sensor Circuit Range/Performance
P0192- Fuel Rail Pressure Sensor Circuit Low Input
P0193- Fuel Rail Pressure Sensor Circuit High Input
P0194- Fuel Rail Pressure Sensor Circuit Intermittent
P0195- Engine Oil Temperature Sensor Malfunction
P0196- Engine Oil Temperature Sensor Range/Performance
P0197- Engine Oil Temperature Sensor Low
P0198- Engine Oil Temperature Sensor High
P0199- Engine Oil Temperature Sensor Intermittent
P0200- Injector Circuit Malfunction
P0201- Injector Circuit Malfunction - Cylinder 1
P0202- Injector Circuit Malfunction - Cylinder 2
P0203- Injector Circuit Malfunction - Cylinder 3
P0204- Injector Circuit Malfunction - Cylinder 4
P0205- Injector Circuit Malfunction - Cylinder 5
P0206- Injector Circuit Malfunction - Cylinder 6
P0207- Injector Circuit Malfunction - Cylinder 7
P0208- Injector Circuit Malfunction - Cylinder 8
P0209- Injector Circuit Malfunction - Cylinder 9
P0210- Injector Circuit Malfunction - Cylinder 10
P0211- Injector Circuit Malfunction - Cylinder 11
P0212- Injector Circuit Malfunction - Cylinder 12
P0213- Cold Start Injector 1 Malfunction
P0214- Cold Start Injector 2 Malfunction
P0215- Engine Shutoff Solenoid Malfunction
P0216- Injection Timing Control Circuit Malfunction
P0217- Engine Overtemp Condition
P0218- Transmission Over Temperature Condition
P0219- Engine Overspeed Condition
P0220- Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221- Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222- Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223- Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224- Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225- Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226- Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227- Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228- Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229- Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230- Fuel Pump Primary Circuit Malfunction
P0231- Fuel Pump Secondary Circuit Low
P0232- Fuel Pump Secondary Circuit High
P0233- Fuel Pump Secondary Circuit Intermittent
P0234- Engine Overboost Condition
P0235- Turbocharger Boost Sensor A Circuit Malfunction
P0236- Turbocharger Boost Sensor A Circuit Range/Performance
P0237- Turbocharger Boost Sensor A Circuit Low
P0238- Turbocharger Boost Sensor A Circuit High
P0239- Turbocharger Boost Sensor B Malfunction
P0240- Turbocharger Boost Sensor B Circuit Range/Performance
P0241- Turbocharger Boost Sensor B Circuit Low
P0242- Turbocharger Boost Sensor B Circuit High
P0243- Turbocharger Wastegate Solenoid A Malfunction
P0244- Turbocharger Wastegate Solenoid A Range/Performance
P0245- Turbocharger Wastegate Solenoid A Low
P0246- Turbocharger Wastegate Solenoid A High
P0247- Turbocharger Wastegate Solenoid B Malfunction
P0248- Turbocharger Wastegate Solenoid B Range/Performance
P0249- Turbocharger Wastegate Solenoid B Low
P0250- Turbocharger Wastegate Solenoid B High
P0251- Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252- Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253- Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254- Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255- Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256- Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257- Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258- Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259- Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260- Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
