View Single Post
Old 01-23-2006, 08:22 PM   #2
12second5.0
Check ya later!
P0261- Cylinder 1 Injector Circuit Low
P0262- Cylinder 1 Injector Circuit High
P0263- Cylinder 1 Contribution/Balance Fault
P0264- Cylinder 2 Injector Circuit Low
P0265- Cylinder 2 Injector Circuit High
P0266- Cylinder 2 Contribution/Balance Fault
P0267- Cylinder 3 Injector Circuit Low
P0268- Cylinder 3 Injector Circuit High
P0269- Cylinder 3 Contribution/Balance Fault
P0270- Cylinder 4 Injector Circuit Low
P0271- Cylinder 4 Injector Circuit High
P0272- Cylinder 4 Contribution/Balance Fault
P0273- Cylinder 5 Injector Circuit Low
P0274- Cylinder 5 Injector Circuit High
P0275- Cylinder 5 Contribution/Balance Fault
P0276- Cylinder 6 Injector Circuit Low
P0277- Cylinder 6 Injector Circuit High
P0278- Cylinder 6 Contribution/Balance Fault
P0279- Cylinder 7 Injector Circuit Low
P0280- Cylinder 7 Injector Circuit High
P0281- Cylinder 7 Contribution/Balance Fault
P0282- Cylinder 8 Injector Circuit Low
P0283- Cylinder 8 Injector Circuit High
P0284- Cylinder 8 Contribution/Balance Fault
P0285- Cylinder 9 Injector Circuit Low
P0286- Cylinder 9 Injector Circuit High
P0287- Cylinder 9 Contribution/Balance Fault
P0288- Cylinder 10 Injector Circuit Low
P0289- Cylinder 10 Injector Circuit High
P0290- Cylinder 10 Contribution/Balance Fault
P0291- Cylinder 11 Injector Circuit Low
P0292- Cylinder 11 Injector Circuit High
P0293- Cylinder 11 Contribution/Balance Fault
P0294- Cylinder 12 Injector Circuit Low
P0295- Cylinder 12 Injector Circuit High
P0296- Cylinder 12 Contribution/Range Fault
P0300- Random/Multiple Cylinder Misfire Detected
P0301- Cylinder 1 Misfire Detected
P0302- Cylinder 2 Misfire Detected
P0303- Cylinder 3 Misfire Detected
P0304- Cylinder 4 Misfire Detected
P0305- Cylinder 5 Misfire Detected
P0306- Cylinder 6 Misfire Detected
P0307- Cylinder 7 Misfire Detected
P0308- Cylinder 8 Misfire Detected
P0309- Cylinder 9 Misfire Detected
P0311- Cylinder 11 Misfire Detected
P0312- Cylinder 12 Misfire Detected
P0320- Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321- Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322- Ignition/Distributor Engine Speed Input Circuit No Signal
P0323- Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325- Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326- Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327- Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328- Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329- Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330- Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331- Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332- Knock Sensor 2 Circuit Low Input (Bank 2)
P0333- Knock Sensor 2 Circuit High Input (Bank 2)
P0334- Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335- Crankshaft Position Sensor A Circuit Malfunction
P0336- Crankshaft Position Sensor A Circuit Range/Performance
P0337- Crankshaft Position Sensor A Circuit Low Input
P0338- Crankshaft Position Sensor A Circuit High Input
P0339- Crankshaft Position Sensor A Circuit Intermittent
P0340- Camshaft Position Sensor Circuit Malfunction
P0341- Camshaft Position Sensor Circuit Range/Performance
P0342- Camshaft Position Sensor Circuit Low Input
P0343- Camshaft Position Sensor Circuit High Input
P0344- Camshaft Position Sensor Circuit Intermittent
P0350- Ignition Coil Primary/Secondary Circuit Malfunction
P0351- Ignition Coil A Primary/Secondary Circuit Malfunction
P0352- Ignition Coil B Primary/Secondary Circuit Malfunction
P0353- Ignition Coil C Primary/Secondary Circuit Malfunction
P0354- Ignition Coil D Primary/Secondary Circuit Malfunction
P0355- Ignition Coil E Primary/Secondary Circuit Malfunction
P0356- Ignition Coil F Primary/Secondary Circuit Malfunction
P0357- Ignition Coil G Primary/Secondary Circuit Malfunction
P0358- Ignition Coil H Primary/Secondary Circuit Malfunction
P0359- Ignition Coil I Primary/Secondary Circuit Malfunction
P0360- Ignition Coil J Primary/Secondary Circuit Malfunction
P0361- Ignition Coil K Primary/Secondary Circuit Malfunction
P0362- Ignition Coil L Primary/Secondary Circuit Malfunction
P0370- Timing Reference High Resolution Signal A Malfunction
P0371- Timing Reference High Resolution Signal A Too Many Pulses
P0372- Timing Reference High Resolution Signal A Too Few Pulses
P0373- Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374- Timing Reference High Resolution Signal A No Pulses
P0375- Timing Reference High Resolution Signal B Malfunction
P0376- Timing Reference High Resolution Signal B Too Many Pulses
P0377- Timing Reference High Resolution Signal B Too Few Pulses
P0378- Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379- Timing Reference High Resolution Signal B No Pulses
P0380- Glow Plug/Heater Circuit "A" Malfunction
P0381- Glow Plug/Heater Indicator Circuit Malfunction
P0382- Glow Plug/Heater Circuit "B" Malfunction
P0385- Crankshaft Position Sensor B Circuit Malfunction
P0386- Crankshaft Position Sensor B Circuit Range/Performance
P0387- Crankshaft Position Sensor B Circuit Low Input
P0388- Crankshaft Position Sensor B Circuit High Input
P0389- Crankshaft Position Sensor B Circuit Intermittent
P0400- Exhaust Gas Recirculation Flow Malfunction
P0401- Exhaust Gas Recirculation Flow Insufficient Detected
P0402- Exhaust Gas Recirculation Flow Excessive Detected
P0403- Exhaust Gas Recirculation Circuit Malfunction
P0404- Exhaust Gas Recirculation Circuit Range/Performance
P0405- Exhaust Gas Recirculation Sensor A Circuit Low
P0406- Exhaust Gas Recirculation Sensor A Circuit High
P0407- Exhaust Gas Recirculation Sensor B Circuit Low
P0408- Exhaust Gas Recirculation Sensor B Circuit High
P0410- Secondary Air Injection System Malfunction
P0411- Secondary Air Injection System Incorrect Flow Detected
P0412- Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413- Secondary Air Injection System Switching Valve A Circuit Open
P0414- Secondary Air Injection System Switching Valve A Circuit Shorted
P0415- Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416- Secondary Air Injection System Switching Valve B Circuit Open
P0417- Secondary Air Injection System Switching Valve B Circuit Shorted
P0418- Secondary Air Injection System Relay "A" Circuit Malfunction
P0419- Secondary Air Injection System Relay "B" Circuit Malfunction
P0420- Catalyst System Efficiency Below Threshold (Bank 1)
P0421- Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422- Main Catalyst Efficiency Below Threshold (Bank 1)
P0423- Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424- Heated Catalyst Temperature Below Threshold (Bank 1)
P0430- Catalyst System Efficiency Below Threshold (Bank 2)
P0431- Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432- Main Catalyst Efficiency Below Threshold (Bank 2)
P0433- Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434- Heated Catalyst Temperature Below Threshold (Bank 2)
P0440- Evaporative Emission Control System Malfunction
P0441- Evaporative Emission Control System Incorrect Purge Flow
P0442- Evaporative Emission Control System Leak Detected (small leak)
P0443- Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444- Evaporative Emission Control System Purge Control Valve Circuit Open
P0445- Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446- Evaporative Emission Control System Vent Control Circuit Malfunction
P0447- Evaporative Emission Control System Vent Control Circuit Open
P0448- Evaporative Emission Control System Vent Control Circuit Shorted
P0449- Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450- Evaporative Emission Control System Pressure Sensor Malfunction
P0451- Evaporative Emission Control System Pressure Sensor Range/Performance
P0452- Evaporative Emission Control System Pressure Sensor Low Input
P0453- Evaporative Emission Control System Pressure Sensor High Input
P0454- Evaporative Emission Control System Pressure Sensor Intermittent
P0455- Evaporative Emission Control System Leak Detected (gross leak)
P0460- Fuel Level Sensor Circuit Malfunction
P0461- Fuel Level Sensor Circuit Range/Performance
P0462- Fuel Level Sensor Circuit Low Input
P0463- Fuel Level Sensor Circuit High Input
P0464- Fuel Level Sensor Circuit Intermittent
P0465- Purge Flow Sensor Circuit Malfunction
P0466- Purge Flow Sensor Circuit Range/Performance
P0467- Purge Flow Sensor Circuit Low Input
P0468- Purge Flow Sensor Circuit High Input
P0469- Purge Flow Sensor Circuit Intermittent
P0470- Exhaust Pressure Sensor Malfunction
P0471- Exhaust Pressure Sensor Range/Performance
P0472- Exhaust Pressure Sensor Low
P0473- Exhaust Pressure Sensor High
P0474- Exhaust Pressure Sensor Intermittent
P0475- Exhaust Pressure Control Valve Malfunction
P0476- Exhaust Pressure Control Valve Range/Performance
P0477- Exhaust Pressure Control Valve Low
P0478- Exhaust Pressure Control Valve High
P0479- Exhaust Pressure Control Valve Intermittent
P0480- Cooling Fan 1 Control Circuit Malfunction
P0481- Cooling Fan 2 Control Circuit Malfunction
P0482- Cooling Fan 3 Control Circuit Malfunction
P0483- Cooling Fan Rationality Check Malfunction
P0484- Cooling Fan Circuit Over Current
P0485- Cooling Fan Power/Ground Circuit Malfunction
P0500- Vehicle Speed Sensor Malfunction
P0501- Vehicle Speed Sensor Range/Performance
P0502- Vehicle Speed Sensor Low Input
P0503- Vehicle Speed Sensor Intermittent/Erratic/High
P0505- Idle Control System Malfunction
P0506- Idle Control System RPM Lower Than Expected
P0507- Idle Control System RPM Higher Than Expected
P0510- Closed Throttle Position Switch Malfunction
P0520- Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521- Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522- Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523- Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530- A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531- A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532- A/C Refrigerant Pressure Sensor Circuit Low Input
P0533- A/C Refrigerant Pressure Sensor Circuit High Input
P0534- Air Conditioner Refrigerant Charge Loss
P0550- Power Steering Pressure Sensor Circuit Malfunction
P0551- Power Steering Pressure Sensor Circuit Range/Performance
P0552- Power Steering Pressure Sensor Circuit Low Input
P0553- Power Steering Pressure Sensor Circuit High Input
P0554- Power Steering Pressure Sensor Circuit Intermittent
P0560- System Voltage Malfunction
P0561- System Voltage Unstable
P0562- System Voltage Low
P0563- System Voltage High
P0565- Cruise Control On Signal Malfunction
P0566- Cruise Control Off Signal Malfunction
P0567- Cruise Control Resume Signal Malfunction
P0568- Cruise Control Set Signal Malfunction
P0569- Cruise Control Coast Signal Malfunction
P0570- Cruise Control Accel Signal Malfunction
P0571- Cruise Control/Brake Switch A Circuit Malfunction
P0572- Cruise Control/Brake Switch A Circuit Low
P0573- Cruise Control/Brake Switch A Circuit High
P0574- Cruise Control Related Malfunction
P0575- Cruise Control Related Malfunction
P0576- Cruise Control Related Malfunction
P0577- Cruise Control Related Malfunction
P0578- Cruise Control Related Malfunction
P0579- Cruise Control Related Malfunction
P0580- Cruise Control Related Malfunction
P0600- Serial Communication Link Malfunction
P0601- Internal Control Module Memory Check Sum Error
P0602- Control Module Programming Error
P0603- Internal Control Module Keep Alive Memory (KAM) Error
P0604- Internal Control Module Random Access Memory (RAM) Error
P0605- Internal Control Module Read Only Memory (ROM) Error
P0606- PCM Processor Fault
P0608- Control Module VSS Output "A" Malfunction
P0609- Control Module VSS Output "B" Malfunction
P0620- Generator Control Circuit Malfunction
P0621- Generator Lamp "L" Control Circuit Malfunction
P0622- Generator Field "F" Control Circuit Malfunction
P0650- Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654- Engine RPM Output Circuit Malfunction
P0655- Engine Hot Lamp Output Control Circuit Malfucntion
P0656- Fuel Level Output Circuit Malfunction
P0700- Transmission Control System Malfunction
P0701- Transmission Control System Range/Performance
P0702- Transmission Control System Electrical
P0703- Torque Converter/Brake Switch B Circuit Malfunction
P0704- Clutch Switch Input Circuit Malfunction
P0705- Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706- Transmission Range Sensor Circuit Range/Performance
P0707- Transmission Range Sensor Circuit Low Input
P0708- Transmission Range Sensor Circuit High Input
P0709- Transmission Range Sensor Circuit Intermittent
P0710- Transmission Fluid Temperature Sensor Circuit Malfunction
P0711- Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712- Transmission Fluid Temperature Sensor Circuit Low Input
P0713- Transmission Fluid Temperature Sensor Circuit High Input
P0714- Transmission Fluid Temperature Sensor Circuit Intermittent
P0715- Input/Turbine Speed Sensor Circuit Malfunction
P0716- Input/Turbine Speed Sensor Circuit Range/Performance
P0717- Input/Turbine Speed Sensor Circuit No Signal
P0718- Input/Turbine Speed Sensor Circuit Intermittent
P0719- Torque Converter/Brake Switch B Circuit Low
P0720- Output Speed Sensor Circuit Malfunction
P0721- Output Speed Sensor Range/Performance
P0722- Output Speed Sensor No Signal
P0723- Output Speed Sensor Intermittent
P0724- Torque Converter/Brake Switch B Circuit High
P0725- Engine Speed input Circuit Malfunction
P0726- Engine Speed Input Circuit Range/Performance
P0727- Engine Speed Input Circuit No Signal
P0728- Engine Speed Input Circuit Intermittent
