Old 02-14-2008, 08:11 AM   #1
2600RPM Blow off blues...
I recently got my car back from Murillos, went in for a boost upgrade and intercooler. Its making 14 pounds of boost and 459hp. At about 2600rpms the car studders and chokes. Murillios is telling me that I will need to relocate the blow off valve and have something custom fabbed. Has anyone else run into a problem like this? Will a bigger blow off valve help?
From 225 at the motor to 459 at teh wheels
Blown98SN95 is offline   Reply With Quote
Old 02-14-2008, 08:37 AM   #2
Lethal Performance's Avatar
I would say you would have to log/trouble shoot what exactly is going on. We had a 99 cobra we did a custome FMIC upgrade w piping from a non intercooled vortech system. We had a similar problem and relocated the maf from the suction to the boosted side. You dont want to vent off metered air that has passed thru the maf allready. Big no no! Unless you have a speed density setup never vent off metered air.
www.lethalperformancesatx.com New website
Dyno Tuning with: Hp tuners,SCT,Diablo and LT1 edit
Email us at lethalperformance@yahoo.com. We will get back with you
Open Tuesday thru Friday 9:00am to 6:30pm Saturday's by appointment only
Lethal Performance is offline   Reply With Quote
Old 02-14-2008, 11:01 AM   #3
First off you didnt say is this a vortech a procharger a paxton etc
also is it liquid or air to air
is it just at 2600 rpm while cruising ? or when you get on and off of it ..
mass air backwash could be the issue this would show up as low and eratic mass air voltage readings at that area and or a short period of eractic acting after a high rpm shift when the most air is dumped.
PSI
Performance Solutions
210-655-6546
10811 nacogdoches road
San Antonio TX 78217
cmr tuners and full service
performance shop.
Old 02-14-2008, 11:15 AM   #4
sounds like MAF backwash or too small of a bypass.
give us more info on your setup.
MIKE
'86 GT:high 12's
Sold
'01 GT:low 11's
for sale
Old 02-14-2008, 11:43 AM   #5
Use the foooorrrrcccceeee!!!
garbonzo1991gt's Avatar
Also is it a blow through setup or a draw through setup?
Turbos FTW...
garbonzo1991gt is offline   Reply With Quote
Old 02-14-2008, 09:37 PM   #6
Vortech V2-sq trim vortech air to water aftercooler. Its fine when you are steadily going thru the gears, its only when your just barely on the gas.
Old 02-14-2008, 09:38 PM   #7
To be honest not sure. What would I look for?
Old 02-14-2008, 09:41 PM   #8
2600ish its the worst but I did notice it was acting up around 3100 also.
