Do the same to the driver’s side to remove cats from manifolds
Now with all that loose your ready to pull the cat and H pipe assembly out(pic 55)Here it is removed now properly dispose of.(pic 56) Now remove the starter, Make sure that you disconnected the battery before you do this or you will short your car out! Note: the red wire is the hot wire from the battery. That’s why you need to make sure its DISCONNECTED!!!!!(PIC 57)
Now disconnect the starter power cable (pic 58) and just let it hang there. Now the starter and solenoid are disconnected (pic 59) start unbolting the starter
