I have a buddy with a 95 5.0 gt. The motor is bad so he wants to put in a 347 now. it is a 347 with a z303 cam. What we are wondering is will it pass inspection?
Motor in car shouldnt matter for insp provided all the smog equit is in place. Cats etc since the 347 will have no physical (apperance) way to tell it is a stroker. If they sniff in your county again as long as the cats are in place and functioning and the motor has a proper tune you shouldnt have any issues.
85GT FACH1 FINISHED
i honestly doubt it. don is right, but with a cam like that, i doubt it will pass
hes goin to just build a 302. thanks guys!
Displacement of the motor isnt the issue it is tuning it correctly and have the smog items in place that will decide pass or fail
85GT FACH1 FINISHED
The 347 is a good idea, he just needs a cam with a friendlier profile. There are plenty of them out there, and a good tune will do wonders.
2004 Cobra...
Just some bolt ons!!!
Mods: Kenne Bell 2.2H, Kenne Bell boost-a-pump, UPR CAI, Accufab Throttle Body, Metco Idler pulleys, LFP dual pass heat exchanger, 62lb Fuel Injectors with harnesses, Custom tune (Diablo Predator), Diablo Mafia, Competition clutch (supports up to 900 hp), Mac Tru-fit longtubes, Mac 3" Catback Exhaust, Mac catted H-pipe, IRS Billetflow Brace, IRS bushings, Full length weld-in sub frame connectors, Steeda Tri-Ax shifter, Eibach Pro Kit, 26 spline input shaft, and DSS Pro-level axles.
Best run so far 11.6@119
he put the 347 in with an e303. he had one laying around so he just took the z303 out. The car is balls fast.
