4 lug 8.8 axle strength
how much abuse can a stock 3.08 8.8 handle? i want to put new gears in but i am worried about the axles or c-clips or anything else crapping out. i have not done anything major to the engine i belive it's stock. i will eventually put 5 lug disc on all 4 wheels but money is tight right now. i am planning on the SVO aluminum girdle with the gear change.
☆★lSs★☆
street driven, on street tires? if so... i believe the stock 8.8 will be more than strong enough.
you'll begin to see problems when runnin' sticky tires at the sticky track.
![]() LSS Member #22 |
Ooh-Rah Marine Corps
Keep in mind that you can buy hardened moser axles for cheaper than you can buy stock axles from ford. From what I have been told the axles are the weak link. Course if you want to be sure, then just get a 31 spline diff with hardened axles. You won't break that.
![]() 88 vert Be polite and professional, but have a plan to kill everyone you meet. |
#4 | |
☆★LSS★☆
#9 | |
#10 | |
☆★LSS★☆
