Old 12-14-2003, 01:27 AM   #1
4 lug 8.8 axle strength
how much abuse can a stock 3.08 8.8 handle? i want to put new gears in but i am worried about the axles or c-clips or anything else crapping out. i have not done anything major to the engine i belive it's stock. i will eventually put 5 lug disc on all 4 wheels but money is tight right now. i am planning on the SVO aluminum girdle with the gear change.
fadlan12 is offline   Reply With Quote
Old 12-14-2003, 02:26 AM   #2
☆★lSs★☆
bandit's Avatar
street driven, on street tires? if so... i believe the stock 8.8 will be more than strong enough.
you'll begin to see problems when runnin' sticky tires at the sticky track.
LSS Member #22
Old 12-14-2003, 02:33 AM   #3
Ooh-Rah Marine Corps
dcm4136's Avatar
Keep in mind that you can buy hardened moser axles for cheaper than you can buy stock axles from ford. From what I have been told the axles are the weak link. Course if you want to be sure, then just get a 31 spline diff with hardened axles. You won't break that.
88 vert
Old 12-14-2003, 11:56 AM   #4
☆★LSS★☆
When your 60 ft times start getting around 1.55 start worrying.Until then you will be fine.
Old 12-14-2003, 10:51 PM   #5
tire's Avatar
What is the first thing to go, carrier or axles? If I'm shooting for sub 1.8's, should I be moderately concerned about anything because this is my daily driver?
Old 12-15-2003, 01:50 AM   #6
i think your 4 wheels studs will break before anything else....
My Garage
Old 12-15-2003, 01:51 AM   #7
i see most stock axles go at 1.65-1.70....-5 lug axles
My Garage
Old 12-16-2003, 03:10 PM   #8
i'm going with a swap from a 94-98 mustang with 5lug 11.5 inch discs
Old 12-16-2003, 03:31 PM   #9
tire's Avatar
i know a guy, pete campbell, that has had dozens and dozens of runs with his 28 spliners (in a 7.5 rear, no less) cutting at least 1.8 to 1.65 depending. he tried to keep it around 1.7, and the axles held. it's probably right around there though.
Old 12-19-2003, 08:41 PM   #10
☆★LSS★☆
My buddy Al is doing 1.60's with a stock 7.5 with no problems!:jeff:
