Results 1 to 5 of 5
Thread: 65 mustang upper and lower radiator hoses bulged.out.
    May 2008
    i drove the 65 stang the other day. the temp gauge stayed in the middle and was running fine. The elec fan didn't even kick on yet. But the one thing i did notice was the upper and lower radiator hoses were bulging out like they had alot of pressure built up. I was thinking i may need a new radiator that flows better cause i have a stock one in it right now. Let my know what you think. I didnt run it for a very long time btw maybe about 10 minutes each way. so im not sure if its in 100 degree weather if it will over heat.
    Se Miro Locoooon! Regular Member Stang_1973's Avatar
    Dec 2003
    SA
    maybe you need new hoses. Ive heard that they can sorta strtch out. If you upgrade id say go aluminum, supposed to run a bit cooler and definately look alot nicer. I plan to go aluminum later on in the '73.
    1973 Coupe:
    351 EFI roller swap(tuned by Ron Bell)
    CAI
    GT40 upper/lower
    Eddie performer RPM heads
    X303 cam
    hedman elite headers
    2.5" pypes full exhuast, X pipe, Violators
    Converted to AOD, edre racing 3500 stall, with Lentech street termintor Valve body and B&M Quicksilver ratchet shifter
    Grab a track front and rear suspension
    Converted to Power Front Disk brakes
    9" 3.50 Traktion lock
    "Clifford" -work truck
    '99 F250 PSD, stock turbo, ext cab, long bed, Bully Dog Switch.chip, AFE stage II CAI, guages, Converted to flatbed duallie
    May 2008
    i was also looking at the performance radiator with the 1" tubes. not sure yet. And good idea i might try getting a new hose as well.
    Dec 2003
    SA
    yea i remember when i first started working on my car. i replaced the hoses, the old ones were all flimsy and the new ones were nice and strong.
    1973 Coupe:
    CAI
    GT40 upper/lower
    X303 cam
    Mama Mia Regular Member 68GEETEE's Avatar
    Mar 2004
    south of brooklyn
    make sure you dont have air in the cooling system.
