Old 04-08-2006, 12:08 PM   #1
Under Construction
Sinister66's Avatar
Send a message via ICQ to Sinister66
66 disc swap question!
Anyone know if 1974 spindles from a ranchero will work the same as the granada.They look the same?
66 MUSTANG COUPE
Sinister66 is offline   Reply With Quote
Old 04-09-2006, 01:39 PM   #2
RIP Cledus Snow
I don't think they will.I believe the ball joint taper is different.
Old 04-09-2006, 02:45 PM   #3
Under Construction
Sinister66's Avatar
yeah you are correct I checked them out and it is.Thanks
66 MUSTANG COUPE
Old 04-09-2006, 02:51 PM   #4
RIP Cledus Snow
The Granada swap is about the cheapest you will find.They are getting harder to find though at your local salvage yard.Last time I did a swap it cost me about $100.I was one of the lucky few that found a car that had brand new calipers,hoses,and rotors.
Old 04-20-2006, 10:31 AM   #5
Under Construction
Sinister66's Avatar
a complete new conversion kit for $535 comes with everything you need plus master cyclinder and slotted rotors.
66 MUSTANG COUPE
Old 09-03-2006, 11:19 AM   #6
coats04's Avatar
i know you can put '03 cobra brakes calipers and lines on.not sure what spindle,ill have to check.
try mustangsteve.com
coats04 is offline   Reply With Quote
Old 09-03-2006, 12:13 PM   #7
smokinjoe's Avatar
Send a message via Yahoo to smokinjoe
For that cobra conversion check out this site vintagevenom.com and for Granda Swap info check this one Home
These are the guys I wanna go w. once I get to that point, as far as the spindles I don't know, but there was one swap I dont remember what where even though the ball joints were different in the spindle, I believe most of the thread and size of the outer tie rods were the same, som maybe if you get the ranchero tie rod, it would work w/ your adjusting sleeve...wouldn't Ranchero spindles really increase your turning radius???
There are so many options out there, just take your time and do your homwork
1970 Mustang, One of the orignial 5.0's
smokinjoe is offline   Reply With Quote
