☆★LSS★☆
The Granada swap is about the cheapest you will find.They are getting harder to find though at your local salvage yard.Last time I did a swap it cost me about $100.I was one of the lucky few that found a car that had brand new calipers,hoses,and rotors.
i know you can put '03 cobra brakes calipers and lines on.not sure what spindle,ill have to check.
try mustangsteve.com |
For that cobra conversion check out this site vintagevenom.com and for Granda Swap info check this one Home
These are the guys I wanna go w. once I get to that point, as far as the spindles I don't know, but there was one swap I dont remember what where even though the ball joints were different in the spindle, I believe most of the thread and size of the outer tie rods were the same, som maybe if you get the ranchero tie rod, it would work w/ your adjusting sleeve...wouldn't Ranchero spindles really increase your turning radius??? There are so many options out there, just take your time and do your homwork
1970 Mustang, One of the orignial 5.0's |
