Old 06-28-2007, 05:48 PM   #1
Send a message via Yahoo to Southernstang93
67 engine swap?
looking at a 67 coupe and it has a 289ci engine , will a 5.0 engine bolt right in or do I have to have fab work done?
Southernstang93
many upgrades
Southernstang93 is offline   Reply With Quote
Old 06-28-2007, 10:26 PM   #2
thesource's Avatar
Trader Rating: (11)
The 5.0 will drop right in place of the 289 . The balance is different and the later engines use a rear sump pan so you will need to use the 289 pan and timing chain cover since it has the hole in it for the dip stick .
Old 06-29-2007, 09:54 AM   #3
you also need different trany mounts to use any of the stock 5.0 transmissions .. however if you plan on useing your trany you will be fine.
PSI
Performance Solutions
210-655-6546
10811 nacogdoches road
San Antonio TX 78217
cmr tuners and full service
performance shop.
Old 06-29-2007, 10:23 AM   #4
You will need to run either latemodel Dampner/Flywheel or early model Dampner/Flywheel sine one is 50oz counter balance and one is 28oz they dont play well together
Old 06-29-2007, 11:17 AM   #5
thanks for the replies they are a big help , I done the 4.6's and 5.0 , but all where fuel inj. , so real new to the carb. also does anyone make a k-member kit for a 67 that is made for a 5.0 engine?
Southernstang93
many upgrades
Old 06-29-2007, 11:21 AM   #6
just use a 289 oil pan.. like was said before all you have to do is the 289 oil pan and timing cover... and make sure you use the right ballancer and flywheel combo.. my friend had a 302/c4 in his 66 w/ NO problems...
Old 06-29-2007, 05:53 PM   #7
keg65's Avatar
dont' forget the oil pump pickup tube to go with that pan
Old 06-29-2007, 09:23 PM   #8
Check ya later!
No such thing as a K member kit for the early models.They do have setups that you can convert to a mustang 2 type suspension but that is welded in.
Old 06-30-2007, 08:19 AM   #9
keg65's Avatar
even a 351 block will bolt in
with the right pan and they even make headers for that swap
Old 06-30-2007, 02:33 PM   #10
Parts guru
ROUSH67's Avatar
Actually AJE makes a K-member kit 64-70 Mustang I bought one for my TT67 fastaback. PM me for more info…
Bryan
Opinions are like a$$holes...everyone has one, especially on the internet....
ROUSH67 is offline   Reply With Quote
Old 07-01-2007, 08:37 PM   #11
k
Bryan
far better off useing the mustang 2 weld in front suspension .. fixes all the geometry problems and is far beefier and cheaper plus you get disc brakes with it.
PSI
210-655-6546
performance shop.
Old 07-01-2007, 08:37 PM   #12
there is no k member
double post.
PSI
210-655-6546
performance shop.
Old 07-02-2007, 07:45 PM   #13
would you have a link to that kit? thanks
Southernstang93
many upgrades
Old 07-03-2007, 08:18 AM   #14
Hers one place also try Hiedt's
Mustang 2 in your front end 65-70
Old 07-03-2007, 08:19 AM   #15
Here ya go
MUSTANG II SUSPENSION PACKAGES
Old 07-03-2007, 01:32 PM   #16
keg65's Avatar
that's what I want to for my 65
Old 07-03-2007, 09:55 PM   #17
thats what I did to my 66 and its gona get a viper v-10 also "
PSI
210-655-6546
performance shop.
Old 07-04-2007, 09:14 AM   #18
Parts guru
ROUSH67's Avatar
The only down side to the mustang II stuff is that it increases the roll center because it moves the motor higher in the body than the original suspension. On the other hand you get the benefit of unequal length control arms which improves your steering ackerman... there are always pro's and con's to each design, anything is better than the old stock stuff that was designed for 15in wheels and bias-ply tires.
B
