8.8 rear end in 67
The 67 has a 8'' rear end right now and I have been thinking of putting a 8.8 ,, will a 8.8 bolt right in or will there be welding? thanks,,,
Southernstang93 many upgrades |
Its not going to bolt right in because it uses a 4 link setup instead of leaf springs . You can make it fit by welding on spring perches though and its not too hard to do .
why though? i was told that unless you're putting serious power, 8 inch is plenty.. and if that were the case, just go 9 inch
If I was going to upgrade an early cr Id go 9in and be done
There's nothing wrong with installing an 8.8 in the car . They are cheap , plenty of used gears out on the market to choose from and most of them come with posi tracts unlike the 9" or 8" did . I'd say go for it if you can find one from a SN95 car and use the disc brakes on the rear .
Box Foxes Rule!!!
Ranger/Explorer(up to 02) 8.8s are leaf spring,weld new leaf spring pads on.
Check backing plate to backing plate measurement.
The car is coming with a 9" rear(not installed as a extra) , but only has the axles , no pig. I not going to get to crazy with this car , I have already had cars that are 500rwhp , and I do not think that is the way I will be going with this car , I will be putting the 9'' up for sale soon and then start to look for 8.8 ,,, I want to add disc brakes to the car and for sure the front but it seems that there not a easy CHEAP way of doing the swap ...... if there is please point me in the right direction ...
thanks
Box Foxes Rule!!!
I want to say Maverick
or Granada disc up frt. Google Mustang brake swap and see what comes up.
hm.. would you be interested in trading yhe 9" for a 8.8"? just curious
For the disc brakes, it is the Granada....check out this site for more info, they actually sell the stuff...but you can grab most of it from a junk yard....
Home and click on "how to" There are all kinds of classic Stang/Granda brake swap sites out there.....
1970 Mustang, One of the orignial 5.0's |
send me a pm and let me know the info on the 8.8 , what all comes with it..
Yeah the granada stuff is what you want for the front end .
Box Foxes Rule!!!
I have a 3.89 geared 28 spline,mini spooled
center section for cheap if intrested for the 9 inch.The gears would run you more new than I will take for it.
#15 | |
thanks
#16 |
Box Foxes Rule!!!
Next ones up from 3.73s.Check your pms.
