Old 07-04-2007, 06:40 PM   #1
Send a message via Yahoo to Southernstang93
8.8 rear end in 67
The 67 has a 8'' rear end right now and I have been thinking of putting a 8.8 ,, will a 8.8 bolt right in or will there be welding? thanks,,,
Southernstang93
many upgrades
Southernstang93 is offline   Reply With Quote
Old 07-04-2007, 06:48 PM   #2
thesource's Avatar
Trader Rating: (11)
Its not going to bolt right in because it uses a 4 link setup instead of leaf springs . You can make it fit by welding on spring perches though and its not too hard to do .
Old 07-04-2007, 09:09 PM   #3
why though? i was told that unless you're putting serious power, 8 inch is plenty.. and if that were the case, just go 9 inch
Old 07-05-2007, 08:16 AM   #4
If I was going to upgrade an early cr Id go 9in and be done
Old 07-05-2007, 09:26 AM   #5
thesource's Avatar
Trader Rating: (11)
There's nothing wrong with installing an 8.8 in the car . They are cheap , plenty of used gears out on the market to choose from and most of them come with posi tracts unlike the 9" or 8" did . I'd say go for it if you can find one from a SN95 car and use the disc brakes on the rear .
Old 07-05-2007, 09:46 AM   #6
Box Foxes Rule!!!
racer99's Avatar
Ranger/Explorer(up to 02) 8.8s are leaf spring,weld new leaf spring pads on.
Check backing plate to backing plate measurement.
of stupidity!
78 Zephyr, 306 turbo
82 Granada Wagon,306 150 shot
88 Mustang 2.3 turbo 100 shot
Old 07-05-2007, 01:59 PM   #7
The car is coming with a 9" rear(not installed as a extra) , but only has the axles , no pig. I not going to get to crazy with this car , I have already had cars that are 500rwhp , and I do not think that is the way I will be going with this car , I will be putting the 9'' up for sale soon and then start to look for 8.8 ,,, I want to add disc brakes to the car and for sure the front but it seems that there not a easy CHEAP way of doing the swap ...... if there is please point me in the right direction ...
thanks
Southernstang93
many upgrades
Old 07-05-2007, 05:17 PM   #8
Box Foxes Rule!!!
racer99's Avatar
I want to say Maverick
or Granada disc up frt.
Google Mustang brake swap and see
what comes up.
of stupidity!
Old 07-05-2007, 05:24 PM   #9
hm.. would you be interested in trading yhe 9" for a 8.8"? just curious
Old 07-05-2007, 05:36 PM   #10
smokinjoe's Avatar
Send a message via Yahoo to smokinjoe
For the disc brakes, it is the Granada....check out this site for more info, they actually sell the stuff...but you can grab most of it from a junk yard....
Home and click on "how to"
There are all kinds of classic Stang/Granda brake swap sites out there.....
1970 Mustang, One of the orignial 5.0's
smokinjoe is offline   Reply With Quote
Old 07-05-2007, 07:58 PM   #11
send me a pm and let me know the info on the 8.8 , what all comes with it..
Southernstang93
many upgrades
Old 07-05-2007, 09:19 PM   #12
thesource's Avatar
Trader Rating: (11)
Yeah the granada stuff is what you want for the front end .
Old 07-07-2007, 09:22 AM   #13
Under Construction
Sinister66's Avatar
Send a message via ICQ to Sinister66
I went with the ford 9"
66 MUSTANG COUPE
Sinister66 is offline   Reply With Quote
Old 07-07-2007, 12:13 PM   #14
Box Foxes Rule!!!
racer99's Avatar
I have a 3.89 geared 28 spline,mini spooled
center section for cheap if intrested for the
9 inch.The gears would run you more new
than I will take for it.
of stupidity!
Old 07-09-2007, 05:51 AM   #15
how much you looking and how close are those gears to 373?
thanks
Southernstang93
many upgrades
Old 07-09-2007, 12:39 PM   #16
Box Foxes Rule!!!
racer99's Avatar
Next ones up from 3.73s.Check your pms.
of stupidity!
