| 4.6 Tech (96-04) Discuss the 1996-2004 2-Valve GT & 4-Valve Cobra |
'98GT-4.10s-Flows
98' speedometer question.
My speedometer only works intermittently... sometimes it reads correct, sometimes not at all, and sometimes it wraps around and pegs against the pin as-if Im going 200mph.
![]() When I bought the car it had 3.73s and the speedo read correct. I later switched to 4.10s and added a speed-cal, but had to mess with the dip switches to get it to calibrate correctly... (purchased used) It seemed to work well, but lately I've been getting a check engine light and (after replacing several sensors and tracking a vacuum leak) the guy working on it says its now showing a speedometer-related code (cant remember his exact term for it), but he thinks the speed-cal is bad. Im not sure what to do at this point... Regardless of wether the speedo is working correctly, the odometer works. Should I just take the s-c out alltogether and get a new one? Is there a replacement gear or would I need a tuner to recalibrate the speedo without the s-c. Are the '98 speedos gear-driven or electronic?
SEEK MEDICAL ATTENTION FOR LIES LASTING MORE THAN 24 HRS....
Elevtronic however there is a gear that drives teh signal unit. It sounds like your gear is bad or the sending unit is bad.
Pull the unit off and ck the teeth on the gear. I cant recall but I beleive the gears are different colors for different sizes (ratios) get the same color you have if yours is bad. Not familiar with speed cal so I guess that could be an issue as well. Try removing it and see if it at least works consistantly.
![]() 04 Oxford White MACH1,5 SPD with IUP,K&NAircharger Borla Stingers,SLP Catted X pipe,Tri-ax,SCT Flashtune,Max Mtr Spt 4 bolt adj C/C plates, Drilled/Slotted rotors all 4 corners. 17x9 frt 17x10 rear D/D Blk bullitt's 281 rwhp on Mustang Dyno,306 rwhp on a Dynojet 94 Black Lightning Daily Driver &85GT FACH1 FINISHED (for now lol...)
'98GT-4.10s-Flows
So if I order one of these I should be able to do-away with the speed-cal?
Speedometer Recalibration Gears - '79-'98 Ford Mustang |
BRING ME MY RAPE SHOES!
ever get it figured out?
getting there h&r ss springs, kyb shocks&struts, 17x9 and 17x10.5 03 cobras, bbk catted x with borla stingers, sct tune and 3.73's.
'98GT-4.10s-Flows
Shop installed a new sending unit.
I purchased the new calibration gear from the Steeda website Wednesday, it arrived Saturday. 15min install, seems to be working fine. problem resolved. |
