Results 1 to 2 of 2
Thread: A/C Question
    LSS Regular Regular Member Rob_Stylez's Avatar
    Jun 2009
    S.A.
    A/C Question
    My car idles from about 500 - about 1400 rpms while the AC is on. While Im driving its not an issue. Is it low on freon? How do I fix this problem?
    Dec 2003
    SanAntonio
    The idle will fluctuate as the compressor cycles. However mine only does about 200 rpms 1k to 800 or so. and then settles once the compressor stays on.
    It may need a little freon cant hurt to have the charge checked. It shouldnt move that much
    85GT FACH1 FINISHED
