Old 09-18-2003, 01:53 PM   #1
A loose bolt
In the picture below, the tube(below the red wire) is missing a bolt and the other is very loose. Would the seal not being tight on the tube cause a vibration in the engine?
edit:Not the gold bar, but the chrome colored tube
92GT is offline   Reply With Quote
Old 09-18-2003, 03:19 PM   #2
Elitist
CHips's Avatar
im not sure if that would cause any vibration, but i would suggest that you fix that real soon
CHips is offline   Reply With Quote
Old 09-18-2003, 03:25 PM   #3
Does anybody know the size of the header bolts for a 302?
Old 09-18-2003, 03:32 PM   #4
Elitist
CHips's Avatar
i cant tell by the picture, but is the loose tube part of your headers, if so, im willing to bet that it would cause vibrations
Old 09-18-2003, 03:53 PM   #5
yeah it is part of the header, I threw the other bolt(while going around the block) so thats why I want to see if anyone knows the size of the bolts
Old 09-18-2003, 03:59 PM   #6
Elitist
CHips's Avatar
i'll bet that would be causing vibrations, especially at higher rpm's. i dont know what the bolt size is, but im sure that someone around here would know:2thumbup:
Old 09-18-2003, 06:40 PM   #7
Check ya later!
It will not cause a vibration!Period!It can cause an exhaust leak though!You said the balancer seemed ok.Another thing you may check that will cause vibration is if the motor mounts are bad.
Old 09-18-2003, 11:12 PM   #8
Elitist
CHips's Avatar
dammit, i thought i had something there
