Old 05-18-2008, 01:32 PM   #1
4 valve FTW
seco's Avatar
ABS light
Recently the ABS light turns on as soon as I get on the highway.
Turns off when I exit. Don't have any issues with the brakes. Doesn't pull to
the side when braking. Brake fluid is within fluid limit, doesn't leak. The brake
pedal doesn't feel spongy or stiff. No uneven wear on pads. Don't think
any pistons in the calipers are sticking. IDK.... I don't have much experience
with brakes other than swapping out rotors and replacing pads. Any ideas?
Ride is a 1999 GT 4.6L 2 valve. All brake system is OEM.
SLP loud mouth cat-back, Pro 5.0 short throw, 4.30 gears, Steeda sport springs, chrome 18x9 18x10 Saleens, NT555's 285/40/18 rear, and an O/R X and RAM clutch soon to come.....
Old 05-18-2008, 01:38 PM   #2
keg65's Avatar
did you change tire size? different sizes front to rear?
Old 05-18-2008, 01:46 PM   #3
4 valve FTW
seco's Avatar
yeah I recently bought new rear 285/40/18 Nittos 555's prolly about 3 months ago or so. The rears use to have 275/40/18's which were shorter in overall height. The fronts I'm running 275/35/18's. The ABS light issue just started recently so I didn't think the tires were linked to the ABS light.... anyone else think the tire size can set off the ABS light?
Old 05-18-2008, 07:49 PM   #4
BlackSunshine01's Avatar
yes it can set the abs light off, what year is your stang? if it is a new edge that is a considerable differance in height from a stock 245/45/17. that could do it. id check the exciter rings on the back of the brake rotors. alot of times they get coated with dirt and debris. instead of looking like a sporcket it will look smooth like a circle so the abs sensor wont read it.
Old 05-18-2008, 08:56 PM   #5
LoneStarStangs Addict
95 BLK Cobra's Avatar
Trader Rating: (3)
My 95 Cobra was turning the light on and off - more random that yours...turned out to be the left rear sensor has a bad connection...replaced the sensor and all is good...I hated that light bein on
95 BLK Cobra is offline   Reply With Quote
Old 05-19-2008, 06:29 AM   #6
Yaeh chech for debris and or dirt on the pu or the ring.
Also may have an intermittent reader or faulty connct.
I have 315/35/17's on my car and no light. Usually the tire size will not effect it
Old 05-19-2008, 09:20 AM   #7
4 valve FTW
seco's Avatar
so what do the "exciter rings on the back of the brake rotors" look like.
Anyone? yeah I'll try cleaning it(them) - thanks
Old 05-20-2008, 10:57 PM   #8
keg65's Avatar
not justa different size tire, but a different diameter tire on the front compared to the rear.
ABS will pick up two different wheel speeds.
Old 05-20-2008, 11:38 PM   #9
Dumb and dumber
Trader Rating: (17)
Reading your post, I'd say just don't get on the highway, it will never come on then.
Can you pull codes on it??
Originally Posted by hoss302
Old 05-22-2008, 09:52 AM   #10
4 valve FTW
seco's Avatar
LOL ... I rarely ever do ... only when I make a trip to eat lunch with wifey during the work week. Yeah I'll probe for OBD codes when the ABS light is on.
Old 05-22-2008, 09:53 AM   #11
4 valve FTW
seco's Avatar
yeah I'm rolling 35 series in front and 40's in rear
Old 05-27-2008, 12:29 PM   #12
4 valve FTW
seco's Avatar
funny thing...... did some highway cruising this holiday weekend and the freakin ABS light would not come on at all. Even drove all the way the fuck to the fort worth zoo and no ABS light... damn grimlin...
Old 05-27-2008, 08:58 PM   #13
Dumb and dumber
Trader Rating: (17)
A little piece of black electrical tape does wonders !!!
