Results 1 to 7 of 7
Thread: adding power
    Newbie fresh fish!
    Jan 2010
    Sherbrooke Quebec Canada
    adding power
    I have a 2005 GT. K&N intake. X-Pipe w/cats. BBK headers. ZEK Nitrous 175 shot.Window switch, 2 step & TH400 full manual transmission.
    I'm running about 11.45's. I don't want to add a supercharger. Other than changing engines hat else could I do to add power? Someone told me to stroke it and add more NOS.
    LSS Regular Regular Member
    Apr 2010
    El Paso
    First question is how much more power do you want to add? You could always forge the bottom end, and stroke it. Of course adding heads and cams will step up the game as well. If you do heads and cams you might want to add a C and L intake manifold or the new FRRP one. Just curious as to why you dont want to add a supercharger?
    I am stroked and blown (procharger @ 600whp) soon to add a 150 shot. I have livernois heads with comp cams 127550.
    Newbie fresh fish!
    Jan 2010
    Don't get me wrong I bought a 2005 GT for my wife with a ROUSH stage 1 and it works great. I just don't like the sound it makes.
    LoneStarStangs Addict Regular Member Jake's Avatar
    Jul 2010
    kingsville
    try cams. i bet u be in the tens ur real close
    Sn95:Cai,65mmTB,373Gears,Spintech Exhaust
    LoneStarStangs Addict Regular Member TheTeacher's Avatar
    May 2009
    San Antonio
    Quote Originally Posted by Tre06GTP1SC View Post
    On stock rods?
  6. #6
    Apr 2010
    El Paso
    No I have completely built the motor
  7. #7
    LoneStarStangs Addict Regular Member Dark04GT's Avatar
    Feb 2010
    NC
    Quote Originally Posted by Jake View Post
    +1. Get some ford racing or comp cams and call it a day. You should like the sound that a good pair of cams puts out.
    DSG 04 Mustang GT
    Performance: C&L CAI, Accufab 70mm TB+Plenum, 24# injectors, Hitech stage 2 cams, MAC LT's, Prochamber, SLP hi-flow cats, Borla Stingers, Steeda UDP, SCT tune, Braille Battery
    Drivetrain: Tri-ax, FRPP Alum d/s, Exedy Mach 400 clutch, Fidanza Alum Flywheel
    Suspension: C-springs, MM CC plates, Tokico blacks, Eibach sways, X2, Steeda bumpsteer, FLSFCs, kyb quads, 17x9's w/ Nitto NT555 275's, Cobra front brakes, Hawk pads & Powerslot rotors
    Mustang dyno: 290rwhp/284rwtq
    A big thanks to Chris@STP for his work on my car
