Old 07-27-2007, 01:26 PM   #1
PearlWhiteGT's Avatar
Anyone running a E303 & Ped Mount RR's?
If so do you have any valve train noise? I have a knocking/clicking noise coming from my valve train & want to know if it is normal. The tech at ford racing said that it was normal with the cam & rockers that I am running.
PearlWhiteGT is offline   Reply With Quote
Old 07-27-2007, 02:30 PM   #2
I don't want a LARGE Farva...
FoxBodyNut's Avatar
pedestal RR's are louder than stock rockers. if you just upgraded and are wondering if its normal, it is. if you want to be sure, loosen and reinstall the rockers. improper lifter preload can produce more chatter...
Old 07-28-2007, 10:58 PM   #3
My engine builder said that the shims under the rockers needed to be replaced with thinner one's so I had my mech do it & it helped a little but there is still chatter. I'm running stock heads, E303 & FMS 1.6 RR's
Old 07-29-2007, 02:31 AM   #4
FoxBodyNut's Avatar
if you had someone who knows what they're doing re-shim the rockers and get the correct preload, thats the best you can ask for. roller rockers are just naturally louder than stock ones. is there any associated performance drop with this noise, or is it only the noise thats bothering you? performance decreases are a whole other ballpark; that would mean trying to figure out whats broken..
one other thing, is it an individual knock/click, or do they all do it? trying to differentiate between valve chatter (needs a valve job) and rocker chatter shouldnt be hard. a bad valve will be much louder and more pronounced. just making sure what you're hearing is rocker chatter, not something else.
Old 07-29-2007, 11:40 AM   #5
thesource's Avatar
Trader Rating: (11)
Its pretty normal . Some are louder than others and replacing the lifters with new ones help a little . I personally wouldn't worry too much about it .
Old 07-30-2007, 07:23 AM   #6
It just doesn't sound right.
Old 07-30-2007, 07:45 AM   #7
LoneStarStangs Addict
Allnuts's Avatar
Trader Rating: (-1)
My friend is running Pedestal Rockers and an E-303 cam with stock heads. They make some noise.
Old 07-31-2007, 05:54 AM   #8
I know that they make some nosie but how loud should it be? I can hear mine bouncing of other cars when i'm driving. Is that normal?
Old 07-31-2007, 01:16 PM   #9
Allnuts's Avatar
Trader Rating: (-1)
Yea thats pretty loud. On my friends car, if you close the hood, you can't hear them make noise. What brand of rocker arms are you running?
Old 07-31-2007, 01:54 PM   #10
FMS 1.6, does he have any shims under the rockers?
Old 08-03-2007, 01:32 PM   #11
mine sounded like a rattle snake
ran great
Old 08-05-2007, 01:28 AM   #12
Lifted78Chevy's Avatar
yea i run, set of e7's that have been work over with a set of crane alumnium roller rockers ped. style, there pretty noise, but took the car into the hot rod shop had mech listen to my ride, said it was normal, sounds like a bunch of like sewering machines...i woulden't worry to much about it.......does it run fine???
1989 LX Coupe 5.0
HP/335
TQ/362
list goes on forever....she slooowww!!
Old 08-06-2007, 08:48 PM   #13
KLMracing's Avatar
yes its normal, i have been running a e-cam for a while with rr and have always had that same noise
[img width=300 height=81] http://i28.photobucket.com/albums/c2...racingcopy.jpg [/img]
KLMracing is offline   Reply With Quote
