Old 07-25-2004, 08:10 PM   #1
AOD leaks from the tail housing or rear pan, what could it be?
What's wrong with the AOD? It leaks alot form the tail housing or pan just above the crossmember. I still have 1-4 gears (until the fluid is all gone then I refill but it leaks bad about a quart a block at 30mph). I had it rebuilt 4500 miles ago. What could be forcing fluid from the rear pan or tail housing?
pacman90 is offline   Reply With Quote
Old 07-25-2004, 08:12 PM   #2
Is it coming from the tail housing gasket?
Old 07-25-2004, 08:18 PM   #3
I don't think so since I tightened some of the rear pan bolts the leak slowed down by 50%. The bolts were already torqued down to spec. I'm pushing my luck going any tighter.
Old 07-25-2004, 08:29 PM   #4
The cork gasket may be split.I'd try a new gasket.Or take it back if there is some sort of warranty on it.
Old 07-25-2004, 09:05 PM   #5
Stalked!
VulvaMan's Avatar
Send a message via MSN to VulvaMan Send a message via Yahoo to VulvaMan
Mine was leaking pretty bad a few months ago. Hoss and I ( Well hoss, while I watched cuz my fatass wouldnt fit under the slightly jacked up car) changed my trans output shaft seal and it fixed the problem.
Dan
VulvaMan is offline   Reply With Quote
Old 07-26-2004, 09:08 AM   #6
Dan
Thanks for the tips that will give me some direction.
