Old 08-24-2008, 11:46 PM   #1
Send a message via Yahoo to X2CRAYZIX
AOD problems on a 90 GT
Don(2K4mk1) and I just removed and replaced my tranny with a rebuilt AOD tranny on saturday and all is well except when i have the gear selector in overdrive it will go thru 2 gears and then it stops there and feels like im in neutral and wont go to next gear also the first two gears it goes through it feels like they are going through way to soon even at low speeds .
Could the cause of this be the throttle valve cable needing adjustment or the shift linkage needing to be adjusted?????Or does it sound like I got taken for a ride on the rebuilt tranny???
Any advice will be greatly appreciated... Thanks in advance for any advice!!!!!
X2CRAYZIX is offline   Reply With Quote
Old 08-25-2008, 09:52 AM   #2
Sonic Blue 85's Avatar
Take it to a good trans shop, not Amco they will get you. You need to remove a plug from the side of the trans, install a pressure guage, then adjust the TV cable, after making sure the shift cable is adjusted correctly. The AODs can burn up with just a few shifts with the TV cable out of adjustment. From what you are saying I would say the trans has already lost at least one gear. AODs are not good transmissions for anyone other than an experianced transmission man with the proper tools to work on. Most everyone will recomend replacing it with a T5, your car will be faster and more reliable.
Old 08-25-2008, 10:06 AM   #3
wishin the money was there for the conversion but thanks for the advice
Old 08-25-2008, 11:09 AM   #4
chiches & nalgas
BigJnSA's Avatar
the source ought to know. i think he is the LSS tranny guru....
Originally Posted by YZF Voltage View Post
i hate everything... except for hate. i love hate.
Old 08-25-2008, 12:21 PM   #5
thesource's Avatar
Trader Rating: (13)
Not with autos ........... the AOD transmissions are junk unless you spend some big $$$ on one .
Old 08-25-2008, 12:43 PM   #6
I plan on doing the conversion down the road when money is available but right now just wanting to have the AOD working so i can atleast drive it to meets and biffs .
Old 08-26-2008, 09:43 PM   #7
adjusted the cables and all is good so far
