Old 05-01-2008, 09:33 PM   #1
spursguy123's Avatar
Back pressure
Good or bad?
spursguy123 is offline   Reply With Quote
Old 05-01-2008, 09:37 PM   #2
4.6stanger's Avatar
Good for low end torque. But then you can get some 4.30s to fix that. Not reall torque numbers on a dyno, but you'll get the feel.
Old 05-01-2008, 10:15 PM   #3
re re
Trader Rating: (14)
Depends on what you are looking to do???
Back pressure in the pooper = bad
Originally Posted by ezblonde
Old 05-01-2008, 10:33 PM   #4
thunderchicken's Avatar
Wink
To many dairy products may cause constipation
Old 05-01-2008, 10:36 PM   #5
re re
Trader Rating: (14)
gob'ment cheese ftw
Old 05-01-2008, 10:38 PM   #6
Talking
gob'ment cheese ftw
Old 05-01-2008, 10:46 PM   #7
Back pressure in exhasut
Old 05-01-2008, 10:49 PM   #8
re re
Trader Rating: (14)
Good for a low to low mild set up, bad for all out.
Old 05-02-2008, 09:07 AM   #9
good if you have a high compression motor
you need a balance if you are running your average n/a street car. running headers and open h can make less hp than a car with mufflers
Old 05-14-2008, 12:13 PM   #10
oLD sCHooL fOOL
seco's Avatar
so.... larger pipe diameter exhaust + free flowing muffler = low back pressure ? seriously how much could too much back pressure or too little back pressure hurt a NA motor?
March under-drive pulleys, RAM H/D clutch, TriAx, Pro5.0 handle, BBK plenum, 75mm PP t/body, C&L True Flow polished pipe, SVT focus fuel pump, UPR O/R X, 2 chambered Flows, Ford Racing gears 4.10's, Eibach Pro Kit, energy suspension spring isolators, NT555 285/40/18s (rear), 18x9 18x10s chrome Saleens, and a shit load of interior,exterior cosmetic upgrades...
Old 05-28-2008, 01:38 AM   #11
gip99gt's Avatar
My car ran better with an O/R H compared to the O/R X that's on there.
04 GT Mods: BBK Plemum * BBK 75mm T/B * BBK Cold Air Kit * H&R Drop Springs * Steeda Tri-Ax Shifter * MAC O/R H * UPR C/C Plates * Flowmaster Mufllers * Diablosport Predator Tuner * 11" King Cobra Clutch * Rebuilt 3650 by Slim Performance * FRPP 4.10 Gears
gip99gt is offline   Reply With Quote
Old 05-28-2008, 09:28 PM   #12
4.6stanger's Avatar
Really?? Ive always heard the opposite..... did you dyno it or track test it?? By how much??
Old 05-29-2008, 12:51 AM   #13
jmblownws6's Avatar
My car has alot of BP from the head to the turbo
My personal profile and my .02
jmblownws6 is offline   Reply With Quote
Old 05-29-2008, 09:46 AM   #14
thesource's Avatar
Trader Rating: (11)
Back pressure can be good and can be bad depending on the setup and over all goals . On a small engine or mild engine , I say some back pressure is needed to maintain torque . On larger engines or more radically built engines , it becomes less of an issue .
There is also a big debate over using a X pipe vs. H pipe .vs no cross over pipe at all . I have always been a fan of the X design because it just seems to make more sense to me . Guys a lot smarter than me have told me that my car would run better with an H pipe over the X and even faster yet with just a simple extension off the header and a non chambered muffler . I still have my X pipe and MAC flowpaths on the car mainly because I like the way it sounds but I might do some changing around to pick up some ET .
Old 05-29-2008, 03:30 PM   #15
gip99gt's Avatar
Pulled harder going through the gears.
