zomg
I sent BamaChips an email so I can get some info on what type of tune and CAI system will be best for my Auto 05 GT and I thought I could share their insight with you guys who are also looking around for a CAI system. I hope this is useful to you as it was to me.
To: ZEROFACTOR Subject: RE: Message from Bamachips.com Hello, On a 4.6 I focus in where the factory left off, the mid range torque curve. My 4.6 programs are aimed more at adding more torque in the 1500-3500 rpm range and with the performance program more top end power as well. On all of my products I can raise or remove the rev and speed limiters. On the automatics I improve the shift quality as well as totally remapping the torque converter which leads to greatly reduced times at the drag strip. Also with the 05 ups I have the ability to remap the Drive-By-Wire throttle system to further help the throttle response and get rid of that annoying lag time. I can adjust for most CAI kits on the market today so please be sure and state if you have one of these kits or plan on purchasing one in the future. If you do buy one later on simply let me know and I can email you a new file for your new CAI. I sell the C&L and X-2 combo for $679 or the JLT2 and X-2 Combo for $549. Either produce very similar numbers on the dyno, around 285rwhp and 305 rwtq with a manual or 285rwhp and 295 rwtq from an auto, both with my 91/93 programming. Either one of the above intakes are great for the Mustang GT and when you purchase the C&L with the Diablo Predator you'll get another $20 discount. I normally create three programs, an 87 and 91/93 performance and a 91/93 torque, depending on what grade of fuel is available in your area. The Torque and Performance programs differ in the range they are aimed at for making power. The Torque is more so a daily driver program that focuses in on the 1500-3500 rpm's band. In order to do so well in that range though it does give up a few HP up top and this is why I break it apart from my Performance adjustments. The Performance program is aimed at more of a 3000rpm and up rpm band focusing in more on the top end horsepower and all out performance driving. This is a great track tune but also works well daily driven. Any of my programs are safe to use for daily driving unless you request a race only tune. I've just recently developed a midgrade or 89 Performance program so if you'd like to substitute it for any of the others then just let me know. Three programs are included for any of the prices below. Here's a quick rundown of what I have to offer... The SCT X-calibrator and Diablo sport Predator w/ 3 programs $379 This programmer come loaded with 3 different custom written performance programs. Simply plug it into your diagnostic port below the steering wheel and tune like a pro. With easy to follow instructions it will retain your stock programming and re-flash your computer with up to 3 different programs there again written for your vehicle. It will typically come with a premium gas performance program, a regular gas program, and a premium torque program. Then if you decide to sell the vehicle or go in for emissions/warranty repair just plug it in and return it to the stock calibration. These tuners will also be able to retrieve and clear trouble codes. For an added bonus it will also be able to datalogg some of your engine's sensors, this only means that it will read these functions not change them. You will also be able to make some changes to your programming using either the user options on the device it's self OR by plugging it into your PC using a USB cable for the X-cal or serial cable for the Predator. The information I'll need from you for your specific vehicle is this... 1.) Year Model 2.) Engine size and auto or manual 3.) Calibration Code 4 digit 4.) Tire size 5.) Axle code or gear ratio 6.) List of mods you've done or plan on doing soon. 7.) Premium Grade of fuel available in your area, 91, 92, or 93 octane. Even if most of your vehicle is stock I will need to know these items due to differences in the base files for each computer. Attached is a photo showing the calibration code location. It's the four-digit code written on the side of the PCM under the hood to the left of the radiator. The axle code is written on the inside of the driver's door on the white label, it will be a two-digit code of two letters. ![]() Feel free to ask any questions that I may not have covered, as I know I can't get every detail in one email. I'll be happy to help. Thank you, Douglas Studdard. Douglas Studdard BamaChips Tuning 205-302-0231 Monday-Friday 10am-5pm Central Please copy this response for faster replies. Please forgive my delayed response as I've been away during the Memorial holiday.
Black 2005 Mustang GT | Flowmaster AT's |Sequential Taillights |
oops dble post
PSI Performance Solutions 210-655-6546 10811 nacogdoches road San Antonio TX 78217 cmr tuners and full service performance shop. Last edited by psiperformance; 06-03-2008 at 10:09 AM. |
so basicly he will do the exact same thing anyone who uses the sct advantage or chipmaster revolution software will do to tune your car.
There is some very misleading lines in the email wich simply are not true and are his atempts at making a lay person who doesn't know the software seem like hes doing something special < IE: low rpm torque tune, high rpm tune > there simply is no reason what so ever you can not do both in the same tune with this software on this car. For example increasing the torque down low does not in anyway effect what you can do up top .. The software is programable at all engine rpm and the changes you make down low for torque production < advancing the cam timing air fuel etc > have no effect on the upper rpm and you can still do the same stuff you would on the upper rpm for power < retard the cam, timing etc.> So the low rpm torque tune and the high rpm power tune are mearly marketing terms for him to make the customer seem to feel like they are getting a better value by getting two tunes one for torque one for horsepower. you can have BOTH in the SAME tune and in my opinion theres no reason not to give the customer both in the same tune.
marketing gimmick i.e. tq tune... haha
I dont worry about being the best salesman
I on the other hand prefer to give the customer the best value and the best product not the best warm fuzzy over something that is not honestly true < low rpm tune high rpm tune > etc. sorry but its a marketing gimik period .. there is no reason at all you can not have the exact same maximum torque number in your maximum horsepower tune as well.. to claim or say you need a seperate tune for each is a marketing gimik taking advantage of the lack of knowledge of the customer.. I perfer the honest aproach over the bels and whistles and make you feel like your getting more aproach. People like that are the same type who will sell you something you dont need to fix a issue For example a customer walks in the door and the car is blowing the spark out on a 05 at 10 psi .. The above type person would imediatly try to sell you a boost a spark and tell you why its so vastly superior etc etc and how you should use msd coils on it and how people make tons of power with them.. I on the other hand would be realistic and say if you just gap your plugs down you don't need to add anything to the car spark wise till your over 18 pounds of boost and that money is wasted because you realy wont gain any power from those parts < dyno proven> IM not saying anything about the type of reply it was a clear forward reply of what he does. but there are gimicks in it to make him sound like hes doing more then someone else and well hes not by spliting them up if you ask me hes going LESS then others as you should have the maximum torque and horsepower in the same tune if the car is tuned right. if hes making more torque down low with one and more horsepower up high with another hes doing it INTENTIONALY with his tuning to take advantage of the laymen. I prefer the honest guy who gives you what you need to get where you want over the slick salesman who sells you whatever he can any day.
PSI Performance Solutions 210-655-6546 10811 nacogdoches road San Antonio TX 78217 cmr tuners and full service performance shop. Last edited by psiperformance; 06-03-2008 at 05:01 PM. |
I've seen a local shop push new LTs on a mustang owner claiming they couldnt tune it due to a leaky slip fit. He ordered new inferior headers to the ones he had and of course it turned out to be a bad MAF, which they then "helped him out" by selling him a 90mm off an employee's car.
what the F I wont give out the names, but I will never refer people to that shop again when I know of such BS. It pisses me off even more since I refered that business to the shop in the first place.
2007 Reflex Silver Wolfsburg Jetta - new hotness 1995 Canary Yellow GTS - Sold 12.81@106.2 w/1.80 60' Boltons/E303 + 3100 lbs + M&H 246 HP/ 290 TQ 12.57 @ 109.21 w/1.76 60' Boltons/GT40Ps/XE270 + 3240 lbs + 555Rs 295 HP / 321 TQ Last edited by 95 GTS; 06-03-2008 at 05:03 PM. |
just the type of think im refering to when i say slick salesman ..
I prefer to fix the problem then try to just throw parts at it
zomg
Thats why I keep my stang stock because I am scared to start adding things to my car...I dont know shit about what parts i need
I will stick to computers ![]()
SUPER SAIYAN - LEVEL 8 PHELPS!!!!
hey i dealt with bamachips and customer service was great. I called about 4 different times before i ordered with him and he was nice and very paitence EVERYTIME!! Cant beat 50 bucks for a tune that nets around 25rwhp. I got the 93 Race tune from him and its GREAT!!!!!!!!
Join the Lonestarstangs Social Group for Mustangs http://www.lonestarstangs.com/forum/group.php?groupid=1
#12 | ||
Laughs at people who hate
![]() I know a lot of people personally who have dealt with BamaChips (being from Bama and all) and they all love them. The quality is great from what I hear. I've never used them personally but I know a lot of happy people. Everyone uses marketing gimmicks to bring in customers. That's business. If he wasn't trying to actively sell himself he'd be out of business. Same for you.
Mustang Evolution - Ford Mustang News, Articles and Forums ![]() Ford Mustang Commercials - Commercials from the first Mustang to the 2007 GT500. ![]() Add Mustang News to your Facebook Profile! Quote:
well i guess you cant convince people but simple truth is
any shop you get a tune from who knows what they are doing is going to be within a couple horsepower of any other shops tune its simply physics you cant break the laws of physics .. car will take x timing with y fuel curve and z cam positioning.. I honestly dont try to sell myself I try to give the customer the information to make the decision IM sure i could mkae much much more money if i took the other aproach but I hate when a salesman tries to just sell me instead of inform me so I have a problem with doing that myself to others. there are several aproaches to doing buisness and trying to sell the customer is one and a very legitimate one. don't get me wrong i never said anything bad about bamas tunes etc. Just that there is no reason not to give the customer the best of both worlds in one tune instead of claiming it takes two and using that as a fsmoke and mirrors sales point because it simply isnt true.
He only charges 50 bucks a tune compared to 80 bucks or more for everyone else i researched. Im sure he could charge more to make more money.
