Old 07-19-2007, 07:43 AM   #1
4 valve FTW
seco's Avatar
battery leads
Here's a dumb question - the stang keeps building up white chalk like corrosion on the positive terminal. I've already replaced the positive lead w/clamp and also used anti corrosion spray they sell at auto zone. The car is garaged kept at home and at work. The negative lead looks great. The car came with a new battery when I bought the 99GT about 2 years ago. I've never had any cranking or charging problems with it. (I'll check battery brand during during) It seems like it the corrosion builds up quick within a spand of 2 weeks. I'm constantly having to clean the positive battery post and lead. This shit is an eye sore.
SLP loud mouth cat-back, Pro 5.0 short throw, 4.30 gears, Steeda sport springs, chrome 18x9 18x10 Saleens, NT555's 285/40/18 rear, and an O/R X and RAM clutch soon to come.....
Old 07-19-2007, 08:25 AM   #2
Pack wheel bearing grease on it, works for me.
Old 07-19-2007, 02:02 PM   #3
balls. eat them.
BigJnSA's Avatar
i use the battery terminal cleaner, and follow that up with the battery terminal protectant spray. but, if dons way works, im sure it would be cheaper.
안녕하세요
Old 07-19-2007, 07:33 PM   #4
Thats the best way to keep away battery corrosion.
Old 07-21-2007, 06:47 PM   #5
Dumb and dumber
Trader Rating: (17)
Dan ... you know you put anal lube on your terminals... don't lie!!
I have seen weird stuff on terminals, grease, vaseline, spray paint, caulking, and just the other day I saw a customers car that still had the plastic wrap on the battery, the red and green terminal covers, and get this.. still had the protector cap on the positive side, how it made a connection, I have no idea.
Originally Posted by hoss302
Old 07-22-2007, 07:51 PM   #6
I use your anal lube for my batteries....
I have seen a lot of the plastic terminal caps still on batteries and the car still starts. Some people dont realize you are supposed to remove them.
Old 07-22-2007, 07:59 PM   #7
balls. eat them.
BigJnSA's Avatar
that stii dont sound good, dan... (are you speaking of D cell batteries for your culo?)
안녕하세요
Old 07-22-2007, 08:18 PM   #8
Dumb and dumber
Trader Rating: (17)
^^ tards
Old 07-22-2007, 08:19 PM   #9
^^ tards
Calling you a phag just dosent work well now......
Old 07-22-2007, 08:20 PM   #10
Dumb and dumber
Trader Rating: (17)
yeah.. your better off calling me more sophisticated things like..... Daddy or Master !!! lol
Old 07-22-2007, 08:21 PM   #11
I think not.....phag.
Old 07-22-2007, 08:24 PM   #12
Dumb and dumber
Trader Rating: (17)
lmao
