Old 04-20-2008, 01:23 PM   #1
highspeed's Avatar
Best Coilover setup for a '94 GT Stang?
I'm looking for information from anyone who has used a coilover setup with respect to the good and the bad.
One thing I must make you all aware of is the application, and that is for mainly street use and cornering. I would like to find a configuration that is truly built as a coilover instead of using a coilover kit for shocks struts that were not born that way.
The more information and first hand experiences the better... So let me here from ya... again!!!
Modz Update!!!
WTB: I need the following parts for my '94 Stang. PM me if you have any one of the listed components laying around or know someone that does.
  • MAF support brace - '94 GT
  • Maximum Motorsports Panhard Bar
  • Canton radiator overflow reservoir
  • Fidanza or Spec Billet Steel Flywheel - (50oz 302cid 10.5" 157 tooth)
  • T56 Tranny with 5.0L Bellhousing & support brace
  • Maximum Motorsports Tubular K Member
  • Maximum Motorsports Tubular A Arms (std offset)
  • Coil over struts
Old 04-21-2008, 02:08 PM   #2
you get what you pay for. I have had one off the reasonably priced ones and it was LOUD.
get Max Motorsport CC plates with a sphericle bushing and Maximum motorsports coilovers. you will be happy. If you are in the market for a tubular k as well, i would get the whole setup from MM. They will discount the more you purchase from them
Old 04-22-2008, 12:00 PM   #3
highspeed's Avatar
Cool... Thanks.
Modz Update!!!
  • Coil over struts
Old 04-29-2008, 11:24 AM   #4
That is what I have on the rally car. Seems to work well.
RichardM is offline   Reply With Quote
Old 04-30-2008, 07:52 AM   #5
highspeed's Avatar
What is your spring rating and what struts are you using?
Modz Update!!!
  • Coil over struts
Old 04-30-2008, 10:08 AM   #6
Bilstein struts. Right now the front springs are 14" at 550 pounds and the rears are also 14" but at 250 pounds. I am in the process of changing out the fronts as the struts may be bent and I am also installing 450 pound springs to get rid of understeer. At least I hope it is reduced.
