Car has a stock block and pistons..
World Products Windsor Sr heads with 2.02/1.60's
x cam
1.6 RR's
Vortech V-2 S-Trim Supercharger..
MSD Distibutor
MSD Coil
MSD 6al
What are some good plugs?
x cam
1.6 RR's
MSD Distibutor
MSD Coil
MSD 6al
Bob Kurgan told me to get the NGK v-POWER plugs.
I have afr heads but the part number for them was 4091 or Ngk r5671a-7
Not sure if that number will work for your heads though.
I run NGK as well. Can't remember the number though. It's 2 ranges colder than stock heat range.
Either the NGK or Autolite Racing plug and like Larry said about two heat ranges colder than stock. Both the NGK and the Autolite racing plugs are fairly easy to get about any store that stocks either brand can get them. If you go to OReilly's, they have will have an Autolite catalog, in that catalog is a section for aftermarket heads. Most every aftermarket head availible is in that catalog, once you find your head it will give you the plug number for that head. A lot of heads I did not think would be in there are in that catalog. You should still go at least one heat range colder than what is listed in that catalog for your head since you are using a blower.
Thanks guys.. Got some 4091 or Ngk r5671a-7 on order.. Will be in at 11:30 .. What would be a good sugested gap on them? I need plenty of spark, but don't want it so big that it gets blown out.
On my mod motor I run them at .34 with 14#s no problem NGK TR-6
yep yep...get a msd box or what not and run um around .030 gap.....no ignition box i had to run mine tight..like .o20 or the spark would blow out at 8lbs of boost.
1989 LX Coupe 5.0----SOLD
Stock 5.0...just got a good set of flowmasters on it i guess....
2004 SVT Lightning #314 of 3781...HP/388 TQ/460.....next and only mode is a whipple blower with 60lbs injectors.
truck is blown and slammed and one of the cleanist trucks your'll find in Texas.
MSD Distibutor
MSD Coil
MSD 6al
I'd try .035. If thats too much go down to .030. I've always heard the NGK plugs work well on forced induction setups.
Thanks Mike.. Did the .035 and so far so good!
