Old 05-29-2008, 08:31 PM   #1
METAL!
BlackSunshine01's Avatar
brake trouble
my 01 gt went metal to metal on the front rotos today. so when i got the parts and went home to change them i couldnt get the disc off to save my life. i used a ton of pb blaster and was using the BFH to try and break the rotor free of the hub. anybody else know any tricks?
Old 05-29-2008, 09:10 PM   #2
Evil Angel
Bigdrumma22's Avatar
Are they the stock rotors? Were you hitting both sides of the rotor? I would also try hitting it all around the edges where the vents are toward the center of the hub. Maybe a bigger BFH is in order?
Bigdrumma22 is online now   Reply With Quote
Old 05-29-2008, 09:12 PM   #3
Don't hate!
Trader Rating: (20)
+1
Or try cussing at it louder...
Old 05-29-2008, 09:18 PM   #4
get a bigger hammer or get your sis or mom to do it lol j/k
ChrisGT2000 is offline   Reply With Quote
Old 05-30-2008, 11:00 AM   #5
blk01gt's Avatar
Send a message via AIM to blk01gt Send a message via Yahoo to blk01gt
on the lugs u might still have the little retaining washer/nut thing u might have to take that off. if u tear it up takin it off i wouldnt worry bout puttin aother one on b/c the lugs will hold it
blk01gt is offline   Reply With Quote
Old 05-30-2008, 11:40 PM   #6
Don't hate!
Trader Rating: (20)
But he has an 01 and I doubt the brakes have lasted 7 years from birth. Good point though, but I am sure the brakes have been replaced some point in time by now.
Old 05-31-2008, 12:44 PM   #7
METAL!
i took off the retaining washers, lots of penatrating lube hitting all around the edges by vents and on hub. going back out this afternoon to try again.
Old 05-31-2008, 12:49 PM   #8
02AFStang
02AFStang's Avatar
I had the same problem. I was at the "Do it your self" Auto Skills Shop at Lackland AFB changing my rotors and pads. Mine were stuck and I was hitting the rotors HARD with a rubber mallet to no avail. Then I got some help from the onsight mech who weigh about 350 lbs. He rared back and smacked the piss out of these rotors and they popped right off, persevearance.
USAF "Above All"
02AFStang is offline   Reply With Quote
Old 05-31-2008, 01:04 PM   #9
Evil Angel
HAHA... NICE... If only we all had a 350lb. friend available when we needed them!
Old 06-01-2008, 08:27 PM   #10
METAL!
damn, what a cluster fuck this turned out to be! so i thought i could get away with replacing the pads and machining the rotors. WRONG! turns out i needed new rotors a left f brake hose and both calipers and my rears were shot too. took all of 8 hours and 4 front calipers to get the job done. i bought 2 calipers from full service and the line fitting for the banjo bolt was striped out. so i had to go to zone and get 2 more. pretty shitty day but at least i know my car will stop now. the only down side is now i cant get my exhaust because i spent the money on brakes.
Old 06-01-2008, 08:39 PM   #11
Evil Angel
HAHA... today I helped my dad do all 4 corners of my mom's Benz wagon and guess what happened when we got to the rear rotors?? STUCK! First thing I thought of was you but after a lot of ZEP penetrant, a rubber mallet, and a big ball peen... my dad said... "get the sledge!" But we stayed conservative and were able to get them off with the mini sledge. Using the full size sledge woulda been a lil' overkill.. And as you know, it was hotter than hell outside so we were also trying not to have a heat stroke or something...
Old 06-02-2008, 09:03 PM   #12
wow I guess some of us are unlucky with brakes I did mine not to long ago and just replaced the pads and had no prob taking off the rotors and had them turn and painted my calipers.
Old 06-03-2008, 04:03 AM   #13
METAL!
well on the bright side i can do brakes on a new edge with no prob now!
Old 06-03-2008, 04:11 AM   #14
Evil Angel
Good! I did mine on my car about a year ago. Only problems I had were the caliper/bracket bolts and the rear caliper with the special tool. The tool I got was kinda hard to use.
Old 06-04-2008, 11:40 PM   #15
METAL!
ya those ones you put on the end of a ratchet is kinda hard to use.
Old 06-05-2008, 07:32 AM   #16
whenever i can't get a rotor off, i smack the hub w/ the air hammer... works like a charm everytime... even on most hondas!
