Results 1 to 12 of 12
Thread: C&L Racer intake install:05+GT
    Unregistered Guest Regular Member DirtyHarry's Avatar
    Nov 2008
    northside san antonio
    I know there are plenty of these but i did my own for fun.
    Tools needed: 10mm socket (extension needed), blade and philips screwdrivers, star wrench(provided), and 2 zip ties(provided).
    Start by disconnecting the MAF by pulling back on the red tab then pull it out.
    Next disconnect the hose that connects to the inlet pipe near the throttle body.
    Then unscrew the bolt connecting the airbox to the inner fender. (10mm)
    Next loosen the hose clamp around the throttle body and pull the inlet pipe off.
    Using the star wrench provided take apart the old MAF and reassemble it into the new housing.
    when reassembling it make sure to use the new philips screws provided.
    next attach the rubber connectors to each side of the inlet pipe, attaching the MAF to the smaller side. (the inlet pipe and MAF should touch each other underneath the rubber)
    Using the 10mm bolt attach the air box to the inner fender. Leave the bolt loose.
    Using a zip tie connect the front of the air box to the ABS lines.
    connect the inlet pipe to the throttle body and line up the MAF to the air box. (dont forget to reconnect the nylon hose on the inlet pipe near the TB)
    reconnect the MAF plug and connect the filter. Dont forget to tighten the 10mm bolt on the air box.
    and thats it.
    06 s197 DD/Project
    1928 Ford Sedan
    Nov 2008
    finish product
    06 s197 DD/Project
    1928 Ford Sedan
    . Regular Member zosick's Avatar
    Jan 2006
    i have the c&l street intake and is tuned required, i believe this one doesnt? correct me if im wrong.
    off topic: what is that on your grill, some kinda of screen or something?
    Hi, I'm an Asshole. Regular Member Steve's Avatar
    Dec 2008
    Fucking your mother, trebek.
    lol he has a womans stocking on it... LOL
    2001 Chevrolet Corvette
    The Vette gets em' Wet, it also handles nice too.
    FAIL
    Mar 2007
    san antonio
    stockings, wtf?
  6. #6
    Dec 2008
    Hey DH, did you unplug your battery and such when you did this?
  7. #7
    FAIL
    Mar 2007
    san antonio
    why would you need to? just wondering.
  8. #8
    Nov 2008
    yes i do have stockings on my grill and what! no i didnt disconnect the battery, and i dont believe the street requires tunning
    06 s197 DD/Project
    1928 Ford Sedan
  9. #9
    Jan 2006
    the street does. i just wanst sure about the racer.
    womens stockings thats creative lol
  10. #10
    Nov 2008
    yeah the racer requires a tune. I hate the look of the stock grille so thats what i got until i can afford cosmetics.
    06 s197 DD/Project
    1928 Ford Sedan
  11. #11
    Regular Regular Member
    Jun 2009
    Brownsville Texas
    The sct racer does require tuning, when I order mine I installed it and tried to run it without one it threw a check engine light and it went to a limp mode...so i order a tune from brenspeed and it was day and night difference from the stock to the c&l racer...
  12. #12
    Newbie fresh fish!
    Nov 2009
    US
    good job done by you...and you just did it as you have full confident on yourself....and this is just an inspiration for others...thanks for sharing these information..it will be helpful for every one
