Results 1 to 4 of 4
Thread: Cams? help
    03 Mustang Gt Regular Member chasev27's Avatar
    Nov 2009
    Frisco
    Cams? help
    I am putting on headers this weekend and after that i am thinking of doing camshaft and gears.. and then port and polish the head etc. and then i am going to put a turbo,procharger or a superchager in in once i get the money.
    what u think and any good cams etc. out ther
    thanks
    Next Time You Think Your Perfect Try Walking On Water
    MOAR LEETERS Weilding the ban-stick proudly JCP281's Avatar
    Jun 2007
    San Antonio
    if your gonna get a blower or turbo wait to get your cams...
    Quote Originally Posted by Steve View Post
    Nah it just looks good when people are behind it in their ancient pushrod tech equipped trailer trash mobiles.
    Regular Regular Member ChaseO!'s Avatar
    Dec 2009
    Webster TX
    Yeah I would do your power adder first and then I go with comps supercharged/nitrous stage 2 cams and 373 gears
    07 GT.
    JLT cold air intake
    Pypes off road X pipe
    SLP Loudmouths
    Pypes axle back race pipes
    Custom tuned by brenspeed
    Comp stage 2 thumper cams
    3.90 gear
    Ram clutch
    BOTTLE FED!
    Newbie fresh fish!
    Feb 2010
    Odem, Tx
    would not do the cams, there are other things that will give you the same or more increase without all that expense. I would definitely do like they say, get the P/A first, then if you want more, do the cams.
    2004 Cobra...
    Just some bolt ons!!!
    Mods: Kenne Bell 2.2H, Kenne Bell boost-a-pump, UPR CAI, Accufab Throttle Body, Metco Idler pulleys, LFP dual pass heat exchanger, 62lb Fuel Injectors with harnesses, Custom tune (Diablo Predator), Diablo Mafia, Competition clutch (supports up to 900 hp), Mac Tru-fit longtubes, Mac 3" Catback Exhaust, Mac catted H-pipe, IRS Billetflow Brace, IRS bushings, Full length weld-in sub frame connectors, Steeda Tri-Ax shifter, Eibach Pro Kit, 26 spline input shaft, and DSS Pro-level axles.
    Best run so far 11.6@119
