88 GT- the car has been sitting for a few months but had this problem before parked. when starting the car- the engine turns over, I press the gas and the engine will rev up then die immediately... I don't think the battery is too good but I had the car hooked up to another car with jumper cables. I did put some gas in the car so that's not the problem but the GAS LIGHT is on when I turn the key on/engine off and the gas light stays on when the car dies... not sure if that means anything...? Thanks in advance for the help. -JM
