2002 V6 5spd. Battery has to be good because the remote still works and the radio and lights work. The car makes a "CLICK" when the key is turned and that's it. What's wrong here??
C&L Cold air, Functional Ram Air Hood, Hurst Short Throw, MAC Offroad Prochamber, Stainless Works Axle Back.
it could still be the battery. The remote and lights dont take as much juice as cranking the engine does. That click is what I hear when my battery dies.
Assimilation has become Emulation
"Heroism and villainy are just two sides of the same coin."
-Felipe Fernandez-Armesto
"A hammer doesn't build a house, you have to put in the work"
-Tony Horton
"Killing time is a subtle form of suicide..."
-Mark Zimmerman
bad ground maybe. but check the voltage of the battery. better yet, put your battery in the car and see if it starts. if it does take the battery to be tested, if its good, check the alternator. there was another thread on this recently.
and yeah what wiked said about the locks and accessories still working, they don't take much juice to work.
2003 DSG Mach 1 - Pro 5.0 shifter, Magnaflow catted X-pipe, Magnapack catback, 31 spline Moser axles, 31 spline Ford Diff, FRPP 4.30s, and Diablo tuner
Sold - 1992 LX 5.0 - TF HCI, other mods -280.6hp/325.5tq
Thats right, clean out your terminals, you might just not be getting enough cranking amps due to a faulty connection
-Tony Horton
-Mark Zimmerman
we just put a new battery in less than a year agoi also drove it to work wednesday night and it wouldnt start thursday, it hadnt been sitting for more than a day. i guess i'll go try and jump it here in a sec
a year is enough time for a battery to go bad. some just don't last sometimes so forget the whole its only a year old thing.
Expecially if its a cheapy... My last car I got used with a walmart everstart in it... got a free on every 8-12 months until i finally bought a better battery.
As mentioned above, you may also check the connections to the posts... they corrode through pretty easy if you have build up and dont take care of them. I had a battery that showed good charge on a volt meter but had a ground terminal that looked and felt ok until I tried to remove it and it fell apart. Replaced it and it started right up.
White 2k 5-speed:Saleen Front,Stalker Hood,Spintech Side Exhaust,Sonic Blue 18in DD Bullitts,Pro-kit, KYB Adj. shocks/struts,MM C/C plates,MM Panhard,MM STB, MM KMember Brace, MM Rear LCA's,Built and Braced 8.8, 31 Spline Diff, 31 Spline Axles,3.55 Gears,Rear Sway Bar,Custom LED lighting, MGW A/C & Headlight Controls, MGW Shift Knob, Black Leather, Autometer bezel, Reverse Halo Gauges, Mach1 grill delete, WE sequential tailights, ASP 25% pulley, MAC CAI, Innovate LC1 w/ DB gauge, MGW short throw, MGW locking fuel door, FRPP cluctch, MM clutch quadrant, MM firewall adjuster, MM clutch cable, 4 Wheel Cobra Brake upgrade, BBK Shorty Headers.
Turned out to be the starter. got a new one put in and it started right up![]()
