Results 1 to 11 of 11
Thread: Carb Help
    Newbie fresh fish!
    Jun 2009
    Trophy Club
    Carb Help
    I have a 67 Fastback GTA that I am working on getting running. The carb is proving to be difficult. Instead of rebuilding it i decided to replace it. I am having some issues with the config of the new one.
    Here is the link to the replacement carb Holley Performance Products 600 CFM Four Barrel Street Carburetor*0-80457S
    Any help would be appreciated.
    Question 1: Does the stop bell looking thing "NEED" to be on the new carb?
    Question 2: How do I mount it if so?
    Question 3: Where do the springs etc.. go .. the documentation is terrible
    I know there are people out there that know how to do this stuff but I am lost.
    Jun 2003
    Trashcanistan
    I'd suggest rebuilding the old one. It's about the most simple carb to rebuild. What you have is the old Autolite 4100. It actually can be quite valuable if it's the original carb.
    Box Foxes Rule!!! Regular Member racer99's Avatar
    Feb 2005
    Cowboy Capital of the World
    1 No you dont.
    2 No need to worry about it.
    3 In the third picture move the
    throttle return spring from where you have it to
    either of the lower holes.Add an
    additional spring from the large upper
    hole foward to a bolt or bracket.2 springs
    are better just in case 1 breaks.
    of stupidity!
    Just damn junk with a blow through
    Dec 2007
    Marion
    Like previously said, the Autolite carb that was on your car is worth a bit of money, they are very simple, very simular to a Holley in function, Holley actualy coppied them when they made the Econo Master carbs and they are good performance carbs. The part you are asking about transfering over, increases engine rpm, if I remeber correct when the A/C is turned on, to compensate for the load created by the A/C compressor. Later Ford used electric solenoids to increase rpm with the A/C on. Yes you can make the car work without it, even with A/C, the old York compressors use a lot of power to drive, the newer Denso compressors that the modern conversion kits use, use a lot less power to drive. So what engine is in your car that had a Autolite four barrel? In '67 the only engines that Ford put in the Mustang that used that carb were the 289 and the 390.
    Newbie fresh fish!
    Jun 2009
    Trophy Club
    Carb Help more info
    It's a 289 manifold and uppers on a 78 Lincoln Versalles 302 block. It also has a custom 4 bolt harmonic balancer so there's no telling what he did to it.
    I sent back the Holley.
    I am thinking of having the current one rebuilt but I am concerned that the guy my grandpa bought the car from did some modification to it and I am afraid that if someone doesn't know exactly what they are doing that they will miss anything that he did to it custom.
    Any suggestions? I am sooo close to getting it running.
  6. #6
    Feb 2005
    Quote Originally Posted by Sonic Blue 85 View Post
    Sell the carb to a collector.
    Why do you say its a custom balancer?
    of stupidity!
  7. #7
    May 2008
    the rebuild should not be a problem to try yourself. If not keep it and buy a used one off ebay. By the way if you want a dead reliable carb you could get a edelbrock 600cfm. I had a carter which is a knock off of the edelbrock that i never once needed to adjust or workon 14 years until i took it off.
  8. #8
    Newbie fresh fish!
    Jun 2009
    Trophy Club
    Autolite 4100 4bbl Carb Questions / issues
    Thanks racer99 for your detailed info in the reply. The car has power steering but not A/C
    I am considering sending the carb off to Carburetor, Carburetors, Carbs, Carb Parts. Pony Carburetors - Your Ford Carburetor Restoration and Part Sales Specialist to have it rebuilt. They are quoting "starting at 359.50 +parts and shipping". This seems extremely high considering I am shipping it to them and providing the good carb for them to rebuild not requiring a core.
    I am attaching a picture of the actual tag from the Carb also for more granular info.
    65mustangscott I appreciate your response as well I am sure I could rebuild it but I barely have the time right now and when I do have the time I probably won't have the money.
  9. #9
    Oct 2006
    Denton
    oh man that's pretty high i would think... have you asked ron or one of our other sponsors?
  10. #10
    LoneStarStangs Addict Regular Member staug347's Avatar
    Dec 2008
    san antonio tx
    TAKE IT TO RON!!!!!!!!!!!
    dude did mine in like an hour
    great guy as well
    www.myspace.com/bexarcountymustangs
    302 carbed
    holley 600
    bbk shorties, bbk x pipe, flows
    hurst short-throw
    5-lug conversion all around
  11. #11
    whoa pony!!! Regular Member keg65's Avatar
    May 2005
    NE San Antonio
    thats a lot.
    Kit would only be around $25 and what $10 for the bucket of chem dip?
    Very simple to do, I would find the time to save $325 to get the same thing.
    2012 Mustang GT
    5.0, 6 speed, Brembo package
    Barton short throw shifter, Magnaflow Competition Exhaust, JLT carbon fiber CAI, SCT X3, UPR uca and lca, JLT oil separator.
