Old 01-30-2007, 01:39 AM   #1
smokinjoe's Avatar
Send a message via Yahoo to smokinjoe
Carb Spacer
Hi-ya Gang,
I have been contemplating getting a carb spacer for awhile, I really have one question/opinion: Should I go with a 1" or 2" spacer for a 302 ci, w/ an Edlebrock Cam, 600 CFM carb, and Intake (the performer package), would 2" be too much of a spacer for this setup?
1970 Mustang, One of the orignial 5.0's
smokinjoe is offline   Reply With Quote
Old 01-30-2007, 10:58 AM   #2
67stang347's Avatar
I use a 1". I'm running a Victor Jr with a 750 CFM. Just be sure it will clear the hood. I had to cut mine
67stang347 is offline   Reply With Quote
Old 01-30-2007, 01:07 PM   #3
smokinjoe's Avatar
Do u think I will need to get a bigger carb if I run a 2"? I actually want to cut out the hood, I wanna run the classic hood scoop w/ butterflies!
Now the next question is which scoop do I run? Any tips on figuring out the height? Do ya'll think that the spacer alone would be enough to raise the normal scoop above the hood, or should I use the scoop w/ the extension?
Old 01-30-2007, 02:16 PM   #4
67stang347's Avatar
I had to cut mine because the carb would not even without the spacer.You could try putting some clay on the air cleaner and closing the hood and measure the height to get a rough idea.
If our hood is orignial I would get an aftermarket and cut that. I couldn't bring my self to cut mine.
Old 01-30-2007, 02:30 PM   #5
67stang347's Avatar
Here is a picture of my hood
Old 01-30-2007, 04:29 PM   #6
smokinjoe's Avatar
That clay idea is a good one! Thanx for the tip...as far as cutting out my own hood I don't think I can bring myself to do it! I drilled out the holes for my hood pins and that was waaaaay high on the pucker factor itself, I can't imagine cutting out a hole for the scoop! I think I'm gonna have it done somewhere...
So what do ya'll think a good setup would be? My 302 w/ the Edlebrock Performer package, 600 CFM, a 1 inch spacer, and the scoop without the extension or w/ the extension? I think i am gonna try that clay idea, I'm just hoping that one of ya'll perhaps has some more experience doing this. Thanx
Ok, just measured it, 5 1/2 inches from where the filter sits on the carb to the top of the hood, That caly trick worked BA!!!!
Old 01-30-2007, 04:30 PM   #7
smokinjoe's Avatar
Do you have a 302 or 289?
Old 01-31-2007, 07:07 AM   #8
67stang347's Avatar
I'm running a 347. When I had the 289 in the car I ran a Erson 500HLH cam with 318 Duration ,244@0.50, 538lift on In &Ex. I have always run the Victor JR and the 750CFM dull feed. The heads were highly worked over.
My friends '69 ran a Erson HI Flow II cam with a Performer intake with 600 cfm on a 302 with and Auto. The heads had so mild work done I think he had 20thousands cut of them. The car ran well and was enjoyable to drive.
Old 01-31-2007, 10:12 AM   #9
67stang347's Avatar
I just had a thought (must have been the 8th cup of coffee) an Eldebrock Air Gap intake may not be a bad fit I think it may be a little higher than the Performer and I think it is a duel plain design. It all depends on how far you want the scoop to stick out of the hood.
I forgot my friends '69 used 1/2 " spacer to get his hood to close.
Old 01-31-2007, 10:22 AM   #10
smokinjoe's Avatar
67Stang, thank-you for all of your help w/ this!
After looking and measuring everything I think I will run the 1" spacer, perhaps the edlebrock, that will reduce my carb to hood clearance to 4 1/2". The hood scoop is about 5 inches tall, so if I go w/ the second one that has the extension I should be able to trim and fine tune the tube so that the bottom of the opening of the scoop is just about flush w/ the hood. I can't wait I have always wanted a hood scoop w/ butterflies on it since I was a little kid
I am still contemplating bumping up to a little bit bigger carb, I really may not need it though, I am pretty much stock except for the Edlebrock Performer package and Accel Ignition....
Ps - Your car sounds like a screamer and looks sharp too!!!!
Old 01-31-2007, 01:55 PM   #11
67stang347's Avatar
Sounds like you got a good game plan. I love the the butterflies too. I'm from PA and the Butterflies were very big up there on everything. I went with the 3" cowel hood to be a little different.
I have not run the car down here yet, getting the carb set right down here is a killer. My best past was done on a cool early fall night in PA at 10.31 at 131mph. I had the 4:62 gears in it and the M&H's on.
Old 01-31-2007, 07:53 PM   #12
keg65's Avatar
butterflies, very old school
not a fan, IMO
But, you'll almost have to trial/error it to find the right size spacer to get the scoop at the right height out the hood.
Old 02-07-2007, 07:18 PM   #13
keg65's Avatar
try long studs and stacking washers under carb to see how thick the spacer should be to make the scoop at the right level
Old 02-07-2007, 08:36 PM   #14
smokinjoe's Avatar
I actually ordered everything today but the actual scoop. Summit should be sending all my new gear by Friday: 110GPH fuel pump, 6-9 psi fuel regulator,1 inch carb spacer (4 hole), & a driveshaft safety loop....
Once I get all of this poop on I am going to go w/ the scoop w/ the extension, this way I will be able to trim the tunnel ram to the exact point where the bottom of the scoop will be flush w/ the hood!
Yay! New parts for the stanger!!!!!!!
