Old 12-30-2006, 10:00 PM   #1
carburator rebuild
ok, next question... how hard is it to rebuild the carberator? i've done a lot of general mechanic work in my day, but that's one i've never tried.
thanks,
lateniteman
lateniteman is offline   Reply With Quote
Old 12-31-2006, 04:50 PM   #2
keg65's Avatar
its not that hard
the kit comes with an exploded picture of the carb and some instructions
buy a gallon of carb cleaner and soak it in there
just pay attention when you take it apart so you know how it goes back.
count the turns on the air/fuel screws from where they are at to bottomed out, that way you will be close when putting them back.
check the clearance on the throttle shaft bushing, they will need to be replaced if the shaft moves.
i'm sure others will have more advise.
You can do it, not too hard.
If you can do that, then it is actually not too much harder to rebuild the C4 automatic trans.
1 of 472
Old 01-01-2007, 01:24 PM   #3
What carb??
Holleys can be a PIA sometimes quadara jets and 2 barrells are pretty easy. Just pay attention during disassembely and watch for little ck balls and springs. They can pop out and be gone pretty easy. Soak it and blow everything oout before reassemblely.
There not to bad usually.
Old 01-01-2007, 04:31 PM   #4
Making people happy, one stop at a time...
chewie's Avatar
Not too bad. In addition to what the others said, not knowing which carb you're working on is kind of limited. If it's a Carter or Q-jet based make sure the surfaces (top, body, throtle plates) aren't warped. Metal straight edge and emery paper is what I have always used to "fine tune" the mounting surfaces. Never had a leak unless the body was really warped by other owners over tightening the screws in previous rebuilds.
My .02
Nature should be allowed to do its job of killing off the weak, sickly, and ignorant people without interference from airbags and batting helmets
chewie is offline   Reply With Quote
Old 01-01-2007, 05:33 PM   #5
i've only rebuilt one carb in my life, and it was the easiest thing ever... kinda tideous because it's lots of small parts.. but i attempted it having never done it before and with nothing but the kit and my haynes repair manual...
Old 01-01-2007, 07:41 PM   #6
☆★LSS★☆
If you can hold a screwdriver you can do it..........
Not quite that easy but close enough.....
Old 01-02-2007, 07:28 PM   #7
I rebuild all my carbs. Pretty easy if you can be thorough on your cleaning and put it back together like it came apart.
