CD Burning Problems...Help!
Ok, I have been fawking around trying to burn some data on a CD/RW for about 3 days now with no luck. It goes thru the paces like it normally does then once it's done burning the program freezes up and I have to restart the puter to get the cd out and there is nothing on it. I have tried Nero and some other freebie and they both do the same thing. This all worked before. It has been a while since I burned a cd tho. Anyone have any ideas? Im thinking the CD ROM driver is bad but I cant find a copy of it anywhere. Help please.
![]() 1988 Mustang LX |
#3 | |
you smell that?!
that same exact thing happened to me a few weeks ago when i tried to install a new external burner. maybe check troubleshooting for the software you're using on google?
94 Steeda- sold- 355rwhp on a 75 ![]() 02 Roush 360R- sold- 400rwhp at 8psi ![]() 04 Mach 1- K&N drop-in, Steeda tri-ax, Pypes o/r X, Super 44s, 04 Cobra IRS, 4.10s
I uninstalled my driver and reinstalled it, no luck. I changed a few deals on the registry and still nothing. I have tried 3 different brand CR/R and CD/RW still nada. This is pissing me off. Im trying to burn data files. I tried music files also, which is usually what I burn but no luck. Any other ideas before I take my shotgun to this damn thing??
http://www.cdburnerxp.se/
Try this program, it works pretty good and is free. if the firmware thing doesn't work. Oh yeah while you're at it update your mobo drivers too. I would also check your Ide connection and/or swap out and try another ide/ata cable. Last edited by John#21; 10-17-2005 at 11:36 PM. |
#9 | |
