Old 11-29-2003, 11:04 PM   #1
Question changing out oil pump and screen
can anyone tell me if it is possible to change out the oil pump in my 1989 lx with out pulling the motor all the way out of the car?
buckshot481 is offline   Reply With Quote
Old 11-29-2003, 11:17 PM   #2
Check ya later!
yes you can do it but why?
Old 11-29-2003, 11:30 PM   #3
a friend of mine insist's that is more work to pull the lotero out then to disconnect the motormounts and just tilt it on the tranmission crossmember. i don't think it will be easier at all. what do you think?:jeff:
Old 11-29-2003, 11:31 PM   #4
what a misspell. it's not lotero, it's motor
Old 11-29-2003, 11:32 PM   #5
Check ya later!
why are you changing the oil pump?
Old 11-30-2003, 12:23 AM   #6
i was driving the car the other day and the oil pressure gauge went to zero. almost as if it was broken. stock dash gauge by the way. i stopped, checked the oil and it was full. drove it a couple miles at slow speed and could hear the rocker begin to tap. this happened thanksgiving day and i just bought the car two days before this.
Old 11-30-2003, 03:09 AM   #7
AdRock's Avatar
I have an oil pump that I believe will work on your 5.0. It's a Melling pump part# M-68. I bought it for an '86 F150 that I had with the injected 5.0. I'm almost positive yours takes the same pump. I'll let you have it for $5 just because I don't really need it anymore.
I did a little searching to make sure it would fit. I found this page
http://www.cantonracingproducts.com/...lling.html#sbf
About half way down the page it has:
289-302 FORD OIL PUMPS
#M-68
289-302 Ford Standard Volume
Old 11-30-2003, 09:42 AM   #8
i appreciate the offer but i all ready bought a new pump and screen. i was just curious of the easiest way to replace it. thanks anyway.:jeff: :threegear
Old 11-30-2003, 09:49 AM   #9
Check ya later!
Sounds like it probably has other issues.Possible bearing clearance.I've never seen an oil pump fail with the exception of being locked up from debris.
Old 11-30-2003, 09:51 AM   #10
what do you mean?
Old 12-09-2003, 05:34 PM   #11
Hey, smell my finger
firegoose's Avatar
He means the engine bearings are worn out or spun (spun a rod bearing) inside the rod cap.
firegoose is offline   Reply With Quote
Old 12-09-2003, 06:45 PM   #12
The easiest way is to pull the motor. Or the other option would be to support the motor with a hoist and drop the K-Member, but I'd opt to pull the motor. Sounds like a lot of work but it really isn't.
Old 12-10-2003, 07:51 PM   #13
Check ya later!
If you have the right equipment you can pull the engine in an hour.:jeff:
Old 12-10-2003, 08:10 PM   #14
Easily. :jeff:
Old 12-10-2003, 08:16 PM   #15
Check ya later!
Originally posted by bighoss88lx
Easily. :jeff:
Speed wrenches rule!
