Old 06-16-2008, 08:53 PM   #1
02AFStang
02AFStang's Avatar
Changing plugs
I am going to change the plugs on my 02 GT. I was wondering if there was a particular brand that was better than the other? The only engine mod that I know of is the BBK cold air intake w/mass air sensor. Thanks for the help.
USAF "Above All"
02AFStang is offline   Reply With Quote
Old 06-16-2008, 08:56 PM   #2
Black Ownz
black_stang_02's Avatar
Motorcraft.
black_stang_02 is offline   Reply With Quote
Old 06-16-2008, 09:00 PM   #3
TonyToughNuts's Avatar
I'm partial to E3, but they are kinda expensive. i paid 60 for 8, but they give me better gas milage over the bosch ones i had. and according to powerblock on spike tv, (i know it's tv) they gave a little more horsepower than the autolite ones they had. all they did was swap the sparkplugs and got 4 hp (engine dyno).
you laugh cause it's funny, i laugh cause it's true
TonyToughNuts is offline   Reply With Quote
Old 06-16-2008, 09:09 PM   #4
Don't hate!
Trader Rating: (20)
Originally Posted by black_stang_02 View Post
Motorcraft.
+ 1
I however have NGK TR-6 in mine due to high compression and tuned for 93 octane.
Old 06-17-2008, 07:53 AM   #5
gip99gt's Avatar
I run NGK's.
04 GT Mods: BBK Plemum * BBK 75mm T/B * BBK Cold Air Kit * H&R Drop Springs * Steeda Tri-Ax Shifter * Steeda Pulleys * MAC O/R H * UPR C/C Plates * Flowmaster Mufflers * Diablosport Predator Tuner * FRPP Clutch * FRPP 4.10 Gears
gip99gt is online now   Reply With Quote
Old 06-17-2008, 09:09 AM   #6
i'm a huge ngk fan but in a stock mustang, just go with the oem motorcraft
Old 06-17-2008, 10:11 AM   #7
Evil Angel
Bigdrumma22's Avatar
Do you really get better mileage? If so... how much?? I've been wanting to try these since they came out a few years ago when I used to work at Advance. At that time I wanted to try them on my ol' chevy truck since she only gets like 9 mpg. Since then I've thought of trying them on the car. I also saw the demo on tv and I wouldn't mind giving them a shot, just haven't heard from many people who have tried them.
To the OP... I'm still running on Motorcrafts and as Mod Man Jody said, that's all you really need unless you're highly modified... I mean... *cough*stock*cough* like Jody.
Old 06-17-2008, 06:39 PM   #8
Don't hate!
Trader Rating: (20)
All I got is a drop in K&N filter..
Old 06-17-2008, 06:56 PM   #9
blk01gt's Avatar
Send a message via AIM to blk01gt Send a message via Yahoo to blk01gt
i have the bosch +4's and i will never use them again put them in and my car is retarted now im gunna prolly go back to the stock motorcraft AWSF-32PM
blk01gt is offline   Reply With Quote
Old 06-17-2008, 07:18 PM   #10
4.6stanger's Avatar
ive heard of that happenin to people, like runnin bad and displayin the mil. Id recommend autolites/motorcraft.
Old 06-17-2008, 08:01 PM   #11
Evil Angel
Yeah, when I worked at Advance they were an easy sell cuz most assumed they were better, but I would actually try not to sell them because of stories I heard from the actual regular mechanics we had come in and the DIYers that knew cars relatively well. They didn't stock motorcraft plugs at the time... maybe now they do...
Old 06-17-2008, 08:38 PM   #12
METAL!
BlackSunshine01's Avatar
i used the autolite xp irridium in mine. iwould reccomend auto lite or motorcraft for a ford. bosch plugs belong in the germans.
Old 06-17-2008, 09:29 PM   #13
Adrock For President '08
timpryor's Avatar
I use the Autolite 764's
<><'98 BAB Cobra #3392 of 5174 Modded-446RWHP/408 RWTQ<><
Originally Posted by PonyTx View Post
you scare me.
Old 06-18-2008, 09:35 AM   #14
4 valve FTW
seco's Avatar
and a flowmaster decal..... j/k go with motorcraft plugs
