Old 12-17-2004, 03:51 PM   #1
Fatal Blow!
Check Engine Light
After i rigged my car up so no coolant or anything goes through the heater core the check engine light came on a few hours after. Then today my car is riding rough and vibrates alot. I think i have a broekn motor mount. but what i want to know is now my check engine light is flashing. Does this mean that the car is in need of real attention or the problem is going away for now.so really i just want to know about the check engine light.
stock96'pony is offline   Reply With Quote
Old 12-17-2004, 04:07 PM   #2
Da Country Girl
BlueStangChik's Avatar
Send a message via AIM to BlueStangChik
Just go get it scanned.
Giddy up my ass, This ain't no pony ride!
BlueStangChik is offline   Reply With Quote
Old 12-17-2004, 04:12 PM   #3
Fatal Blow!
well after my friend gets back with me from ford and tells me how much then it will be fixed and wont be ghetto.
Old 12-17-2004, 10:16 PM   #4
"The Hitman"
Hammered's Avatar
Newer mustangs have a onboard diagnostic function built into the odometer..I am not sure if your year does..but try and see...
1. Place key in ignition.
2. Push trip button in and hold in.
3. Turn key to "on" position.
3. You will see the screen flash with your mileage reading and then the word "test"
4. When you see "test" start your car.
5. The screen will now display the reading "gauge"
When it goes to "gauge" you will notice your gauges (i.e. Tach and speedo) will max out and then sweep back.
6. Keep pushing the trip button until you see some codes with P---, these are the error codes that your car is throwing
Here is a link so that you will know what the error code means
Error Codes www.fordscorpio.co.uk/codes.htm
If not just Google it...I hope this helps..good luck
Larry
Old 12-17-2004, 10:20 PM   #5
"The Hitman"
Hammered's Avatar
Sorry bro..Looks like they did not start offering this until 1999....
http://www.mustangworld.com/ourpics/fcar/dtcodes.htm
Good write up though
Old 12-17-2004, 10:25 PM   #6
Rob
ZZzzzz...
Rob's Avatar
Larry
I believe that is with the digital ones, which started in 99.
97 Black on Black SVT Cobra
#81 of 6961 Born on 09/06/1996
Rob is offline   Reply With Quote
Old 12-17-2004, 10:39 PM   #7
Your CEL may be flashing because it is recieving a misfire from your ignition system. I see it a lot at work. Make sure your spark plugs arent fouled out, misplaced plug wire, bad plug wire, and moisure in the ignition system.
Old 12-18-2004, 12:38 AM   #8
Fatal Blow!
would a busted motor mount cause the CEL to come on?
my engine shakes like a beast now ecspecially when i put the gas in.
Old 12-18-2004, 01:51 AM   #9
"The Hitman"
Hammered's Avatar
Not unless the shaking motor has caused another problem..IE it caused a wire to come loose...
Old 12-18-2004, 05:07 AM   #10
ccs
Most likely ignition misfire, as previously mentioned, unless an injector connector is loose. Water in a spark plug well, from coolant?
jim
ccs is offline   Reply With Quote
Old 01-04-2005, 11:07 AM   #11
Fatal Blow!
I got it checked out and there was water in the 5,6,7,8 spark plugs between the boot and spark plug. after that it runs a little better but it still idles rough. The diagnostics machine gave an error code having to do with the harmonic balancer, but the computer wouldnt let him look it up. I am also getting new spark plug wires today (hopefully), but i dont think this is gonna fix it although it should. Also when the guy cranked it up he siad it sounded like a bent rod.
Old 01-26-2005, 01:54 AM   #12
ccs
Huh, let us know what you discover. The water should only have caused a boot prob, as it's external.
jim
Old 01-26-2005, 08:36 AM   #13
☆★LSS★☆
Sounds like the coolant got past the spark plug boots just as Jim and Hoss had stated earlier.Did you blow out the spark plug holes real well? Did you replace the plugs?
