Old 11-08-2003, 10:43 PM   #1
Check Engine Light
Something odd has been happening that has me stumped. My check engine light comes on(when I am on the gas) randomly during 2500 rpm and 4000 rpm and it will go out as soon as I let off the gas. I know there are things that can cause the light to come on for short periods of time, but repeatedly and only when I am on the gas? I just changed the oil yesterday and it started last night and has been doing it ever since. Any suggestions would be appreciated..
92GT is offline   Reply With Quote
Old 11-08-2003, 11:27 PM   #2
MODIFIED
checked your oil level yet.> could be short maybe..?
MAC CAI, Spintech Dual Side exit exhaust, Prokit, 99 GT Rear Swaybar, AGX 5 way Adj., FRPP Clutch, MM Firewall Adjuster, MM Clutch Quadrant, ASP U/D Pullies,MGW Short Shifter, MGW Billet A/C knobs, MGW Locking Fuel Door, Upgraded Seats, Custom Interior Paint, Interior LED Setup, MM C/C Plates, MM STB, Cobra Brakes, Sequential Turn Signals, Saleen Front Facia, Stalker Hood, Sonic Blue DD Bullitts.
Old 11-09-2003, 09:49 AM   #3
"The Hitman"
Hammered's Avatar
i would look toward the O2 sensors due to the increased flow during throttle....one may be going bad...
Old 11-09-2003, 01:30 PM   #4
check out your vaccume lines... could have knocked one off changing oil...
good luck,
-Larry
a few bolt ons and Lot's of juice!
97 v-6 running 12.4's
rudestang is offline   Reply With Quote
Old 11-09-2003, 04:41 PM   #5
Thanks for the suggestions, the oil level looks good, all the vacumm lines are ok and I am going to check the o2 sensors.
Old 11-09-2003, 07:16 PM   #6
Check ya later!
The complaint you have described sounds like an EGR and EVP sensor(on top of EGR).Pretty common to see.
Old 11-20-2003, 11:02 AM   #7
So I went and pulled the codes and it came back as the TPS. I am going to replace it and I had a few questions. Do I need to disconnect the battery? Will the TPS require tuning after its on? Last, I wont burn as much gas now right?
Old 11-20-2003, 02:51 PM   #8
Ooh-Rah Marine Corps
dcm4136's Avatar
Have you set your TPS voltage since you put on your new t-body. Maybe you don't need to replace it, just need to set it. I would try this first as it means you won't have to buy new parts.
If you have never adjusted your TPS before This article on www.50tech.com explains how to do it.
88 vert
Old 11-21-2003, 03:01 PM   #9
Cool, thanks for the article
Old 11-21-2003, 04:17 PM   #10
dcm4136's Avatar
No worries man. Glad I could help.
88 vert
Old 11-21-2003, 04:51 PM   #11
Can anyone suggest a good digital mutli-meter? I went to radio shack and they had like 10 different ones but none looked liked what I need.
Old 11-21-2003, 04:58 PM   #12
dcm4136's Avatar
I just went to advance auto parts and picked up one for like 20 bucks.
88 vert
Old 11-28-2003, 11:57 PM   #13
i have a 91 HB GT, where do you plug in a code reader or where do you pull codes from?
fadlan12 is offline   Reply With Quote
Old 11-29-2003, 12:05 AM   #14
dcm4136's Avatar
There is a Jack on the driver side of your engine bay near the back that you plug the code reader into.
88 vert
Old 11-29-2003, 12:20 AM   #15
does it say EEC test?
Old 11-29-2003, 12:00 PM   #16
dcm4136's Avatar
Not that I remember. If you look at the plugs on the code reader they match up to the plugs on the port.
88 vert
Old 12-05-2003, 06:37 PM   #17
Yes, just pull the black cover off the plugs and plug them into the scanner.
Now on to my problem
code 13: RPM out of specifaction during normal idle operation or
D.C. motor does not follow dashpot.
What does that mean and what can be done to fix it?
Old 12-05-2003, 10:54 PM   #18
Either your warm idle is too high or too low.
