Old 11-12-2007, 10:30 PM   #1
89-cobra's Avatar
Check Engine Light 89 FOX
was wondering if any one has the scanner to scan codes? I know a couple shops close by but they want a arm and a nut to check it.. Any ONE I will meet any where. PM Me a price and place
89-cobra is offline   Reply With Quote
Old 11-13-2007, 06:02 AM   #2
i met a guy on the west side that had one.. i bought some e7's from him once... my car came with one, but that doesnt' help you out... BUT i wanna say on the 93's you just have to jumper 2 wires and read the blinks.. oreillys has a diagnostics book for this
t-5 swap, billit quadrant, upr firewall adjuster, steeda tri-ax, custom jb tool and fab one off subframe connectors, 8.8 w/posi and 4.10's with 5 lug axles, tubular upper control arms and southside lowers
next, '00 gt brakes, followed by my 306 swap
Old 11-14-2007, 11:26 PM   #3
89-cobra's Avatar
any one??
Old 11-15-2007, 07:04 AM   #4
2001 Oxford White Mustang GT
aguilarf's Avatar
Trader Rating: (9)
I may have a scanner that would work. I will have to go home and verify though. I think it works on 88-96 Ford. I used it on a 1995 F150 that had the 5.0 engine in it. Kid is right you plug it in and blinks out the error codes, then you cross reference in the book. I will check the toolbox tonight.
aguilarf is offline   Reply With Quote
Old 11-15-2007, 09:26 AM   #5
89-cobra's Avatar
Originally Posted by aguilarf View Post
I may have a scanner that would work. I will have to go home and verify though. I think it works on 88-96 Ford. I used it on a 1995 F150 that had the 5.0 engine in it. Kid is right you plug it in and blinks out the beep codes, then you cross reference in the book. I will check the toolbox tonight.
but what kid said, will it work on ma 89 as well?
Old 11-15-2007, 09:48 AM   #6
aguilarf's Avatar
Trader Rating: (9)
I don't know how to do it without a scanner. I have attached a pic of the scanner that I have. Here is a description.
* Ford & Lincoln-Mercury 1981-1995
* Accesses Ford's self-test system
*Audible and visual indicators
*Compatible with 1981 - 1995 Ford & Lincoln-Mercury vehicles
* Some 1994, 1995 and all 1996 and newer Ford vehicles are OBD II-equipped.
Here is the GM way for doing it. Not sure which pins would need to be shorted for a Ford.
On the aldl connector under the dash, short the "A" and "B" openings with a paper clip and read the flashes of the check engine light. A code 12 { one flash pause then 2 flashes} means the system is operating. Any other code will follow and is flashed 3 times. This works on all GM previous to '96
Old 11-15-2007, 10:57 AM   #7
89-cobra's Avatar
would you be interested in letting me check it out, PRICE?? or pm. i hate buying and replacing parts if not needed
Old 11-15-2007, 11:01 AM   #8
aguilarf's Avatar
Trader Rating: (9)
I'm on the NW side of town, near Sea World. If you want you can pm me. I should be home by 6. Maybe we can meet somewhere convenient.
Old 11-15-2007, 11:13 AM   #9
89-cobra's Avatar
pm sent
Old 11-15-2007, 09:13 PM   #10
UT Sucks
They are $30 to $40 bucks at most auto parts stores the last time I checked.
Darren
Old 11-15-2007, 09:45 PM   #11
aguilarf's Avatar
Trader Rating: (9)
Here is how to check codes with out a scanner.
Old 11-16-2007, 07:31 AM   #12
89-cobra's Avatar
i'll check that out when i get home
