Old 04-13-2008, 10:27 PM   #1
d_stang_j's Avatar
Check engine light 95 GT?
My check engine light keeps turning on and off while im driving, but never stays on, i kinda wish it would so i could pull a code on it, but since it wont im a lil stuck, it seems to turn on as soon as i lift off the throttle or push the clutch in rolling to a stop, now it doesn't do it all the time but two or three times a 10-15 min drive, and ive also noticed that it only does it when i get on it a lil or a lot and then lift, but normal cruising is fine...? Mods are trickflow set up (intake, heads, cam), maf, tb, plenum, cold air, 410s, tune, etc...
d_stang_j is offline   Reply With Quote
Old 04-13-2008, 11:08 PM   #2
Closed for the season
REDHOT86's Avatar
There are 2 different kind of codes... There's a Continues Memory code that even thought the light is not on there still might be something there. I say run the test and see what you can find. Here's a couple links that can explain it more. If you browse through the first one you can find what all the codes mean.
Ford Fuel Injection How To Run a Self-Test
http://fordfuelinjection.com/files/self_test.pdf
Good luck and pm me if you need any help with those websites or whatever. -JM
Mods: 3.73s, Shorties, MAC o/r H pipe, MAC catback, AOD w/shift kit, MAC cold-air, Underdrive Pullies, lowered 1.5" all the way around T5 CONVERSION COMING SOON!!!
Originally Posted by 04Roush2 View Post
All that money and will still sound like a weed whacker
REDHOT86 is offline   Reply With Quote
Old 04-28-2008, 06:53 PM   #3
d_stang_j's Avatar
yea forgot about those codes, we use to call them soft codes, but anyways found the problem, said it was my IAT sensor, turns out when i was giving the car a lil gas the motor was rockin just enough even with the new upgraded motor mounts to make the IAT sensor hit the shock tower and i guess break contact for a split second, so i adjusted the c&l intake tube a lil and problem solved, thanks again for the reminder
