Old 12-25-2007, 05:53 PM   #1
Clutch slipping??
The car runs fine in a straight line but when you give power around a turn it seems like the clutch slips. Start smelling the good old clutch smell. When it idles it has a lil squeaking noise but if you push the clutch pedal just a bit it goes away. I have been told this is the throw-out bearing. Will this cause the slip. I also had gears installed a while back and wondered if maybe they might be slipping. Any ideas. Keep in mind this is the 3rd clutch in 3 years all installed by the same shop and all had the sqeak. The shop told me the squeak would go away after break in but it never did.
MODS:
Cobra body kit,98 COBRA 32V Engine,C&L inlet pipe,BBK single blade T/B, Walboro 255 fuel pump, MAC O/R X-pipe,MAC Catback, Steeda x2 Balljoints, Tokiko shocks & Struts,Bullit Shifter & Pedals, FRPP Gears, Cobra Brake Conversion,2003 Cobra Rims,FRPP underdrive pullies, UPR caster/camber plates
98stangman is offline   Reply With Quote
Old 12-25-2007, 06:56 PM   #2
4.6stanger's Avatar
Take it to another tranny shop and get their opinion, and tell the shop your using what they said. But IMHO 3 clutches in 3yrs DAMN, id stay away from that shop!
Old 12-26-2007, 08:29 AM   #3
TonyGT
TonyGT's Avatar
Send a message via AIM to TonyGT Send a message via MSN to TonyGT Send a message via Yahoo to TonyGT Send a message via Skype™ to TonyGT
time for a new clutch man...been there with my old ram clutch.. u can get a centerforce clutch for like $250 they're awesome
Mustang GT 2000 32V powered- 2006 Chrysler 300 Touring v6 3.5
TonyGT is offline   Reply With Quote
Old 12-26-2007, 12:47 PM   #4
lazer96gt's Avatar
your throw out bearing is bad. this won't cause it to slip though. if you've gone throught 3 clutches that fast, I would say that you have several possible causes. First is that the flywheel has not been resurfaced on any of the clutch installations. second, you have contamination on your flywheel, clutch, or pressure plate. have any leaks? a rear main seal can sometimes make it's way to your clutch. freeze plugs as well. another possible cause is improper down shifting. not to say that you do, but just a possiblity. also just poor quality clutch assemblies. as for the slipping while turning, your LSD could be giving out, but you wouldn't be smelling it though since it is basically sealed except for the vent tube. if your LSD is slipping, then going around a corner under acceleration will cause the inside wheel to spin resulting in raised RPMs and burning tire smell, but not a clutch or carbon smell.
96 SVT#6858 of 7496
Old 01-10-2008, 07:15 AM   #5
I used to go thru alot of clutches as well. Then I got the high end Centerforce clutch and the wieghted pressure plate, and have not had no slipping or any problems. It really is a great clutch, just get the double adjustable cable for it and its not to bad to step on.
Blown98SN95 is offline   Reply With Quote
Old 01-10-2008, 08:00 AM   #6
lazer96gt's Avatar
not to highjack the thread, but how is the high rpm shifting with that weighted Centerforce? does it ever not let go?
96 SVT#6858 of 7496
Old 01-10-2008, 10:22 AM   #7
Its a great combo. More grip, with a tougher push thats all.
